I print one. It is just a click away with octoprint.
Thanks for the advice !
For the straight H type nickel better go with this
The one I used is for spacers so it is designed for a little bigger distance between cells.
I weld a fucking brick. Do 8 nickelstrips(8P configuration) in series withstand 120A?
Depends on the size of your nickel. Iād be happy with it with 0.15 x 12.
Also, before you wire up the foot pedal on your kweld, consider putting a little plug on the lead for it. It is a pain in the arse to store it away with the foot pedal attached.
I say definitely yes.
Donāt forget that in our application you will only see 120A for a few seconds at the most if at all.
There are cell level fused packs where the wire section is a fraction of a nickel strip (even taking into account the difference in conductivity of copper).
Iāll also dig into the cell level fusing topic, before I start welding.
In my opinion, especially for a brick type pack, all it does is introduce more failure points.
A brick is easy and the more solidly it is constructed the better.
Use H type strip or wide 25mm and donāt look back.
Donāt forget to reinforce the first and last p groups with some extra nickel or copper wire.
BMSwise Iād go for a D140 or Smart bms or maybe a DieBieMS.
I havenāt had any problems with the D140.
I have a smart BMS destined to go in an ebike pack but have not hooked it up yet so canāt provide any feedbcack.
Thanks mate. I love your board. One of my favourites in the forum and the type of boards I feel are most suitable for an urban environment (drop deck + pneumatics).
My local dudes are running them. @Pryside
Anyways. It will be awesome, when I build my own battery.
any suggestions for 30amp cell connections?
Iām thinking about using this for the P connections, couldnāt find 40mm wide strip.
I think Iāll use copper braid for series. this is going to be a 120amp batteryā¦
For this type of battery/deck combo you need flexible series connections so I would go for cable if you put the series connections on the side (provided the cable fits).
You could also go for this type of series connections
@taz thanks for the input.
re: copper braid, it seems very flexible to me when you donāt soak it in solder. why would it be less flexible than a round cable? presumably the same metal in a similar configuration, just flatterā¦
I do not have first hand experience with braid.
I have seen a few failures online though so I tend to avoid it. Maybe I should give it a try at some point.
Itās a little tricky because if you arenāt quick enough or donāt use the right technique the solder can run from you pretty quick. I usually get my iron nice and hot and try to work at the very edge
Itās flexible, but it canāt stretch as the board flex, if you use a pair of curved wires they can stretch easily
ah. ok. for that battery I did gap it a little so it could bend without strain.
trying to cram this battery under a @BigBen single stackā¦ seems like 2x10g may ruin my form factor
