I think a lot of it has to do with not being lazy - it shouldn’t be the first or second option for higher current paths and i feel imho it is used instead of better methods because of poor planning or trying to save money/time using methods that are perfectly appropriate for different applications - Not having a welder that can do thick narrow strips so stacking thin narrow strips is not as good of a method as using wider nickel or using a more capable welder.
There are places you can cut corners- like stacking a small strip to make balance lead connections cleaner and flatter - that i think are perfectly fine. But not using the correct rating series connection because you want to be done now with the stuff you have is poor practice and shouldn’t be encouraged especially with new less experienced builders who maybe haven’t thought through all the consequences.
Just my 2¢ but a blanket “stacking nickel is fine” is bad advice and a better way would be “where are you stacking and why” and here is where it’s ok vs not ok
 will probably be fine but not the best.  I shake my head at you in disappointment
 and im not really interested in an argument unless you are having fun too so know im just here to hash it out for fun.  Not trying to prove you wrong or call you names except if it’s light hearted and taken as humor.
 i would totally smoke a test battery for science.  It would be really interesting to compare methods that are assumed equivalents
