Copy that. I will match the grade on the modified edge to the machine edge.
@jack.luis is there a reason u downvoted this comment?
@Evwan
yes
Can u say why spot welding nickel to nickel is not good? @Evwan
can you stop pinging me
@Evwan you canât say? I didnât think there was any reason. Years of spot welding stacked nickel âŚmakes me think either they dont know what theyre talking about or just negative people.
We disagree with the statement you made. Isnât more complex than that.
Spot welding nickel on nickel doesnât work fine? . Can u elaborate? Itâs been done like that pretty universally by diy people for ages.
No.
Yea I didnât think either of u would. If u find how welding nickel on nickel is not good please post it.
It works but itâs an outdated method of building and creates significantly more points of failure in your pack. It works, true but is it the most robust method when building a battery? Not even close. This is why it fell out of favour.
A diagram of your pack orientation would be helpful but you can pretty easily figure your ampacity using the current conductor table. 0.2mm x 10mm nickle will comfortably do about 30 amps cont so figure out which way your current is flowing and do the math.
Assuming youâre doing a standard brick pack config in 8p, that means youâll have ~155 mm length of nickel. So:
155á10Ă30= 465 amps cont. This is plenty of headroom.
Awesome thanks, I didnât think I could just devide the nickel sheet by 10mm and calculate, but it makes sense.
Is spot welding the last p group to a copper bus bar an acceptable method?
Good luck hah
I have tried this and its nearly impossible without a laser welder
Yeah, but sometimes you gotta do what you gotta do.
Yeah battery building is definitely something you can do in a casual manner
Thatâs why Iâm such a notoriously casual guy
Not many people know this but Benjamin here used to be a drunken mobster
Everyone in here who us saying âdont stack nickelâ has done it plenty without issue. Personal skill issues is where faulty welds come up.
Is it ideal? No. Is it fine as long as you test tune and verify your welder settings, yeah.
This is much more driven driven by a grudge against one member for past dumdums, than by battery building ideals.
AFAIK, welding nickel to itself with no can under is more problematic than stacking on a cell.
