That’s weird, have you messaged them yet?
I’ve bought the 8p stuff four times and all of them had extras in the package
I would suggest putting some glue/silicone/double sided tape between the two long halves of the battery.
I’ve seen several staggered packs like this where the side that overlaps ends up riding up the other side.
I put several beads of hot glue between them, you think that’s adequate? There was one I could feel wasn’t super solid, but i took it apart and redid the glue.
Should be ok, but it’s hard to give a definitive yes/no. Also make sure it is nicely padded between the enclosure/deck, then you should be sweet
They haven’t gotten back to me yet. From what I’ve heard abt their customer service I’m not holding my breath though.
It should be better now, when did you message? It is the weekend, after all
I messaged on Friday so its understandable they haven’t gotten back to me yet
Always good to keep tabs on how things are going with vendors - if you remember, let us know what happens
should throw some mineral oil in one of those next pack fire containment tests. @TheBoardGarage
Great for cooling!
Not so great if there’s a fire. ![]()
To be transparent… When I run a battery fire bag test, the goal is to make the battery react as destructively as possible. Generally I’m trying to see what the bag can handle.
Unless I’m talking about the most recent test…which failed miserably because I got too frugal, didn’t pre-test enough, and ended up wasting tons of time and money.
So…yay.
What were we talking about again?
Sorry to hear about this. ![]()
Wishing you unbridled carnage and destruction next time! ![]()
Looks like G10, a fiberglass/resin laminate used for circuit boards, insulators, and other electrical purposes. Often called FR-4 if it has indeed passed the flammability testing to get a FR-4 rating.
Thanks! looks like I can find them with the search term “Circuit insulation board”
I don’t see people on here use them but it looks like most of the Chinese packs would have them
This is genius. I used the 3D printed end clamps to hold them together but I’d have to print different ones for different P groups. Yours is so much more versatile.
I use FR4 for my bigger (200+ cell) packs for non-esk8 customers. Helps keep huge packs like that rigid and uniform. I buy mine from www.eplastics.com
Though is it especially useful for using as a middle divider in packs like this:
How do you cut it?
You can usually score and break materials like this
Looks pretty similar to acrylic no?
