The battery builders club
Lower current certainly helps reduce phantom voltage rise but I think you should be able to help things by lowering your charging voltage or getting all settings up and away from the charger’s voltage (which might not be a good idea, depending on the charger voltage).
You have a very complex set of thresholds set up now, all trying to handle the symptoms you are seeing, but IMO never addressing the cause of all the symptoms…which hasn’t been discovered yet.
Try a lower charging voltage, even if you will never use it. This is just for testing to see if the charge finishes properly, going through a full CV stage down to the termination (charge stop) current setting level…if there is such a setting.
Keep your protection settings high and start balancing about 0.2V/cell below your charge voltage, e.g., 3.8V/cell balance start for a 4.0V/cell charge voltage.
2018/19 everyone used Samsung 30Q
now Molicel P26A is the new norm it seems
i see that they have lots more A, but does it matter that much?
Also they’re 2.6Ah vs 3Ah which i don’t like… (if i’d have the space i’d go for 21700 cells)
In actual runtime the p26a ties or beats the 30q within our range. Rated capacity is generally not a factor we can look at for the high drain of esk8.
can’t really see what you mean
Moochs e-Rating is about the same and the as expected 30Q last more Ah than the P26A
only thing i see is that P26A has less initial sag and is about 0.1V higher (does this make much of a difference?)
wait
in a 12S pack 0.1V adds up to 1.2V sag
But that just means i don’t have the same top speed?
sry, quite some time since i last looked into batteries
When draining at 10-15A, the P26A remains in a usable voltage longer than the 30Q. It also doesnt unbalance as badly.
what’s ‘usable voltage’ for us?
The p26a delivers as much energy total as a 30q at 10 amps, more at 15 amps, and can be pushed to higher currents. It is also much cheaper from what I’ve seen. The 30q may be better below 10 A, but it’s still much more expensive and most of the time we’re looking to use more power than that.
How I understand it
30Q has more initial sag and drops to 3.5V within 300mAh
P26A has less and drops to 3.6V at 300mAh
at around 1500mAh they even out at 3.2V
2300mAh both 3V
P26A more or less dies within the next 100mAh
30Q still has about 300mAh
are we powering off at a higher voltage or what am i missing?
using following charts
*looking at the 20A data
On the escore table, the p26a beats the 30qs at 15 amps. 30Qs have an unbearable amount of sag at 15 amps compared to the tolerable amount of the p26a.
In terms of usable voltage, when your battery is lower, the 30Qs are gonna sag down to the soft cutoff of your esc much earlier than the p26a. You’ll have more usable power on the lower end.
Not to mention how bloody unreliable 30Qs can be. Dead cells, really quick degradation, inconsistencies make them a pain.
I think the main thing is that energy, which is what really matters in the end, is basically the integral of this curve. Being higher for most of the curve outweighs the little bit at the end.
so this basically means we don’t really care about everything below 3V anyway (for battery safety?)
ok, found the meaning of the escores (Wh down to 3.2V)
didn’t know they have quality issues
One question though… how do i need to calculate range if using the mAh won’t do it?
I use total Wh divided by the Wh/Km number to find out approximate Km able to be traveled on a charge.
So this is how the electronics and batteries are built over at Boards of Sweden!
Cells and all the electronics are glued/potted to the enclosure with natural curing silicone.
Everything uses connectors so it’s a simple task replacing parts.
The Xenith and Bmses heatsink is permanently glued to the enclosure so you replace everything but the heatsink if something where to fail.
Enclosure has a layer of glass fibre on the inside and deck has a thick coat of epoxy on the bottom.
Enclosure is super rigid at each segment to protect the cells and handle impacts. While less material and a flexible epoxy is there so the enclosure can flex with the board.
3D printed pieces with a grid structure on the bottom siliconed to the enclosure and velcro plus hot glue for the wiring harness
Butyl tape to make keep the water out, and acts as a strain relief for the enclosure screws.
Always open for input & improvements!
but like…
Wh = V * Ah
So for a 12S3P (12 * 4.2V) * (3 * ?Ah)
wh is measured at nominal voltage.
12x3.7x3
I use Wh because it takes voltage into account. it’s better than saying “I have a 10Ah battery” and that meaning different things when considering the Voltage. 1Ah on 12s isn’t the same as 1Ah on 10s. Wh however is more representative of capacity, so I use that.
what affects capacity values are things like internal resistance and the load applied. if we want to pull tonnes of amps from our cells, the capacity will reduce faster as a result. I don’t know of a way to accurately communicate capacity without caveats like that.
Wh can be measured at any voltage.
Wh=Ah*V
my question is
if the 2.6Ah cell lasts longer than the 3Ah
doesn’t that fuck up the calculation if i use the cells Ah rating?
sort of, which is why you need to take into account the current you’ll be drawing.
this is starting to go beyond my understanding, I hope someone else can chime in with better explanations.
