Not a great idea, it will be more of a pain to construct, and you will also need to have parallel connections between each pair of cells unless you want them to drift over time.
Much better to make twelve 2p units and then connect them all in series.
Ah ok Iâll try the 2p set up seems more convenient. Does anyone make a box what doesnât need spot welding yet?
Look up NESE in the search bar
Thatâs interesting but no balancing connectors.
Any lowering of the current draw = less sag. 20A is the absolute highest I would run that pack. 12A would be better.
Whether going to 20A makes a noticeable difference in your range I canât predict. Try it.
Cheapest cell for high discharge?
??? If it has series connections, it has balance connections.
That question is unanswerable.
We donât know what high discharge means for you. Are you willing to have lower performance for lower cost? What size cell? Would you give up max power for more range?
If you just want a recommendation, the details be damned, buy Molicel P42Aâs.
Hmm over 20A discharge till flat 18650/2100 size 5000mha?
And my other two questions werenât worth answering?
Added
Lol your username does describe you accurately.
There is no 5000mah 18650
There also happens to be no 20a 5000mah 21700
Two big standards here are Molicell P26a (2600 mah) 18650 (20a?)
Molicell P42a (4200 mah) 21700 (25-30a)
Okay, so you arenât going to answer my questions.
There are no 5000mAh round cells rated over 15A and are really more like 10A cell. And they are 21700âs. You can run the 21700 Molicel P42A at a solid 25A fairly efficiently. Try it.
Yep.
Hmm so there are 5000mah cells? 10a might be able to pull it off with gearing.
10a is still pushing those cells close to their limit. How many P groups are you wanting
12s3p if Iâm going with 10a cells. 6-1 gearing 23mph tops single drive 115mm wheels.
You might, maybe get a bit more range at 10A/cell with the BAK N21700CG-50 cells compared to using the Molicel P42A but if youâre going any higher than 10A burst then go with P42Aâs as the voltage sag will be smaller and youâll actually get better range with the lower capacity, but more efficient P42Aâs.
BAK sounds like a off brand cell does it corrode? P42a it is then.
