You probably wont notice anything, especially if you use a really big soldering iron like 150w and do it fast, but it can get messy with that many wires and lots of solder
Just use a hair dryer or a ligher
@BCoad I have but Im in Croatia and it would probably take a week or two to get thereā¦
When my cells get damaged i use the 18650 cell shrinkwrap
No, I have never used that tape or any tape to insulate my cells
Ahh i think i misread your post thanks anyways i pretty much decided to wait for the fishpaper (dont really feal like being the one to try that stuff for science)
just stumbled on this last night, active cell balancers. unlike bms, which bleeds off excess charge via resistors at full charge, these things transfer charge from cell to cell if it detects drift beyond 0.1v. and it does it at a pretty high rate of 1a.
https://www.youtube.com/results?search_query=active+battery+balancer
immediately ordered one to test.
has anyone used one of these before?
i really want to stop using bmsā - theyāre so goddamned finicky.
Iāve ordered one as well. Iāve got a 12s6p Im building currently, hopefully this will get here in time to test on this pack.
I ordered one 6s and 13s as well. I think soon we get some good information about them
oh shit, thereās a post. sorry, should have searched.
anyway, letās see how it goes.
No problem. Itās good that we have this in this thread as well.
Awesome. Thought they were more expensive. What u think of skipping the bms and just using this
@KfromtheBay @ducktaperules wouldnāt he have been fine if heād had the fuse put on the side with the battery in the diagram above. And that wouldāve disconnected and not rely on the individual cell fuses. All the cell fuses seem a risk if they were to break off in the battery and float around
Why no 10s on these active balancing boards
Do ten on the twelve
if you ask the chineese will make it
You can just skip the ports you donāt need. Thatās what as min the supplier said. So 13s work for everything below that.
Oh I like this Idea
right, my understanding is unlike a bms that needs total pack voltage to start balancing, these balancers are looking strictly at each cellās voltage. thatās why it works for all chemistries.
So, Iāve built a few batteries, all with a BMS. Im finding it difficult to decide if this cell balancer should be on while charging directly to a packs pos & neg leads or charge to 80% and then turn it on/connect it. Any ideas?
not sure, i donāt have nearly enough experience to even guess.
me either, I guess we will figure it out .
