Hi! Instead of spread updates on this build everywhere, better to make a dedicated topic. The purpose of this build is to replace my current commute board (“The Avenger” | Jet Spud | MAD Fury DIY Direct Drive | 12S3p 30Q | Focbox Unity ) with a short AT. I was inspired by the amazing work of @ervinelin with the Mini Rolling Fortress. I want to be able to ride without care too much about bad roads, since I am always carrying 2 backpacks ecc…That being said I also want to make something epic to me so…
Idea:
Parts:
ChooChoo deck by @rey8801 lol… The acknowledgments for the name go to @deucesdown
I first tought just 3D printed. It would be fine for few tries. But then I wanted to experiment with the router. It’s a small router so I divided in 3, here one but i made all of them. They came out really nice. Need to glue them together and sand a bit.
Yeh I post everything. It’s part of the game Heat I think I basically I could even get to frame to touch the vaccum machine everywhere to apply the suction. I think I need to lower the mold to the surface (I wanted the gap to jmhave better corners) and way more heat. To even heat up the ABS.
The suction with 2 vacuums connected is pretty strong in my test when the frame touched the rubber seal you need quite some strength to pull it.
2 shop vacuums is what I’ve seen the successful youtubers use.
One design which impressed me was a heating chamber on one side vacuum chamber on the other with the media(abs) hinged on the middle, flip from one side to another after it begins to sag…I think kydex was used
I think I need to build something to place the heat on the top and then the ABS just right below. That what I see the most. So it can sag down with no problem and get heat it up better. Plus the actual heater is slightly smaller than the ABS sheet, so Need to figure it out what to use.
I never give up, I will make the enclosure with that shape, no matter what .
