@GetThorped, @NullBlox, Im glad you are interested in the TTL system. It hasn’t officially launched for sale yet, but I am soooo close to it. My day job, planning for my wedding, and many other little things have kept me from finalizing he project for a while now. I pretty much just have to nail down a some details about the kits I will offer and pull the trigger on ordering bulk of all the parts needed.
To get started on nailing down those details, I have some questions for everyone:
Headlight Cable Length
From the beta kit requests, I’ve seen that ~30" will suit most builds.
- 25" (58cm)
- 30" (76cm)
- 35" (89cm)
0 voters
Tail Light Cable Length
From the beta kit requests, I’ve seen that ~20" will suit most builds.
- 15" (38cm)
- 20" (51cm)
- 25" (58cm)
0 voters
Horn Cable Length
- 20" (51cm)
- 25" (58cm)
- 30" (76cm)
0 voters
Side Light Cable Length
The beta testers were all supplied with 12" cables for the side lights and I did not get any complaints.
- 12" (31cm)
- 16" (41cm)
- 20" (51cm)
0 voters
System Type Interest
I’d like to know the ratio of how many people are interested in each of the system types; Self Powered (SP) and Externally Powered (EP).
SP systems run off of 6-12S (24-48v) and just need to be plugged directly into the battery (or anti-spark switch). EP systems run off of 12v DC provided by an external 12v power supply.
The SP system can provide up to 2.5A total to the lights. The EP system, can handle up to 10A depending on the external 12v regulator used. Therefore, the EP could support much more powerful lights than the SP system.
- Self Powered (good for cruisers and low profile builds)
- Externally Powered (good for eMTBs or high speeds)
- One of Each Please
0 voters
Side Light Type
I’d also like to know the ratio of people interested in each of the RGB side light types; Analog and Digital (addressable).
Analog strips are all the same color. Digital strips allow for theach LED to be set to a different color. Both have plenty of light modes to choose from.
- Analog (lower cost, less complex effects)
- Digital (higher cost, more complex effects)
0 voters
