Summer 2021 E-Games of D.I.R.T
Lol I guess I’m just a noob when it comes to naming, submission is good, could be a little cleaner but I’ll accept it
Also the last minute of the video is just black, idk if that was intentional
My videos are made from a template I made for the first one.
So sometimes I leave in the blank areas on accident, so kinda intended.
Not dogging the naming of tricks though.
It’s truly like learning a new language, in a way.
Even I mix things up.
I thought a bean plant was a boneless.
Then upon checking Im not using the hand for bonelsss, and discovered bean plants!
I honestly thought I had been doing a bonless but with a different hand. Nope different hand means different trick. So we are all kinda in the same boat. Im just trying to keep things as intended as much as I can. :slight_smile:
you think it’s possible to do a 360 drift with 1wd?
Hmm maybe… As long as you can get enough traction to keep moving I suppose.
My jump deck is running again!
Oh mylanta it is so light with only 30 cells 🪶
First Tryyyy!
Drifting is just so much fun.
The only thing bothering me is that I have a flat tire like very 50-100km…
looks like the weather got me today :frowning:
it’s getting harder n harder to keep up
Yea weather and short days is also getting more of a problem for me.
short days for me are fine, maybe i can do it in the dark assuming it can be captured ok
but it started sleeting tonight and that means my board is at more risk
i’ll still ride in the wet, but trying tricks n falling and the board goin in all orientations in rhe wet is not ideal
wet makes drifting easier :wink:
alright alright, ill do it for the wet lol
hopefully y’all can see whatever’s hoppening in the dark lol
edit: i don’t think conditions were good tonight but it’s hopefully visible action! i’ll edit and upload rn
Maybe give slime a try. Did help me a lot.
I use https://armor-dilloz.com/ seems to work better than slime imo.
Also seems to balance easier than slime for myself.
Interchangeable?
Cheap?
Loose tolerances?
Love that marketing, lol
The underlaying problem is that our tires are just shit. There are E bike tires that run for thousands of Kilometers without flats. We need tires that are thicker and more resistant.
we need michilan or however it’s spelled
mihshelen
michigan
michel micael
6.5/8/9” tires
ohmygosh
my american date lookin butt thought the drift was due on friday and i got a letter :joy:
even tho i usually write “ddmmyyyy”
looks like i got some wxtra time!
Here’s my drift. The sand was maybe a tad too deep to do it faster… Had so much fun doing it this :smiley:
Yep you have till this week friday
Due to time constraints I was going through my footage tonight and this is what I came up with
I’ll make a proper edit later with my fails and stuff
If one if these isn’t sufficient then I’ll have to take my extra week, I think I’m good though looking at the other attempts
As usual my battery was on its way out by the time I got to these attempts (after falling over about 35 times), so the wheelspeed was not real high, not kicking up much dirt
FS No Comply 180
  • I’ll accept 170° or greater
  • Board must be off ground
  • Foot must go back in binding
Advice:
  • roll that board forward as far as you can before lifting
  • step back far with your front foot
  • 85% lift, 15% turn
  • don’t smash your toe on the deck :crazy_face:
