Here we go again. Got some more progress and purchases to report! First, I bought some random stuff I needed from Amazon today, washers, washers, bolts and some fishpaper ( I don’t feel like getting roasted for not putting fish paper and using Kapton… you know who you are )
Next thing on the list. I opened up my Panther battery in hopes of finding good news of a disconnected terminal, however, I was disappointed and met with 0 volts on the middle cell
On one hand this is why I used Hobbyking’s RMA, on the other, I was really hoping I could fix it. That being said, if there is anyone that wants a panther battery to harvest two cells out of, PM me and we can work out a price for it and I’ll ship it your way.
After overcoming this disappointment and plugging in my new one to charge, I started working on other things. Since I received the pulleys from TB with the keys, I decided to test fit them. Unfortunately, I was met with a slight oversight - apparently, the shafts on the BKB motors here are pretty short and don’t actually protrude enough into the pulley to capture the setscrews on the end. @torqueboards do you know what size the in-belt grub screws are supposed to be? They look like M3 but it’s hard to tell.
Next thing on the list was to change out the connectors on the MakerX Go Foc Retro. Since the BKB motors use MR60 connectors, I figured I would keep with the clean look of them and change out the bullets on the vesc to match. I’m used to soldering 10AWG wire for most of my main wire runs but I used 12AWG for the motor phases since I had some this time and that’s what the vesc used to have on it. It solders quite nicely into the MR60’s, here’s some pics for yall.
The whole package at the back looks pretty nice, and @YUTW123 again I’m super happy with the small size of the dual ESC, it really saves me a lot of space in this build. I hope it will be able to hold up to the 12S that I’ll be feeding into it. I decided to set it up today with 9s using some lipos I had sitting around just to make sure that it worked but once the battery is done it will be running straight 12S.
I’ve got a lot of things left to do, but progress is progress, I will probably continue on my battery spot welding journey tomorrow with the new lipo from Hobbyking. After that, I’ve got the heatshrink that I’m still waiting for from Aliexpress that needs to get installed around the cells. I will need to plan out and drill all of the inserts into the deck, cut the insulation for the edges, drill holes in the enclosure, etc etc. Happy to see progress and I look forwards to riding this more every day
During setup today I used a VX1 I had laying around, but I will be using a different one for the final product.
