So my original plan for using this drive with boardnamics trucks did not work at all.
What I ended up doing was taking a metal file and filing down the top part of the hanger until it aligned correctly and the bolt could be inserted easily. Then I carefully tightened the caliber adapter while checking the alignment constantly.
I reassembled the drives and it works perfectly.
One additional thing I did a while back and forgot about. I bought 60mm shoulder bolts from McMaster Carr so that they fit correctly with no spacers.
