Hi, Luis, do you fix yours? Here is the instruction file of how to flash firmware by SWD
How to flash firmware through SWD interface - EN.pdf (1.0 MB)
Damn showing proof that you tried to search! Impressive show of regularity.
If it isn’t possible, you could always get a RTS/auto shut off flipsky antispark switch
will not. unless you use uni1 remote, it can be set for auto turn off for ubox
Can I use the remote to program the ubox to auto-shutoff then continue using a different remote?
I’m afraid it’s not workable in this way.
Hi, Guys,
also highlighted here: the single version is launched. get early birdprice to test soon . thanks!
75V 100A single ESC single ubox based on VESC | Spintend.com
Finally I found some time to start building my.board. almost a year later
Was going to apply the foam and A+B glue and the other glue to the pcb… Opened the case and saw this sticker pointing to what looks like burn marks…
Also the fist pin on the same row looks burnt. And the 8th pin is almost bridging the 9th…
One of the smd cap has solder on top of it. Probably don’t matter but I rather show it here before something goes wrong while I riding it. Also found a couple of loose solder balls around the same area…
Should I be concerned about this?
@AmySpintend
oh, sorry for it. it’s production miss. please ship it back to us for replacement new one. but new one will be ready to ship in next week
That’s some damn good service! Appreciate it! Can you PM me a return address?
Email support has been fantastic. Anyone who ordered recently know the shipping time to US?
All support has been fantastic. I’m talking with them on Facebook
Ordered about a month ago and the shipping was ~3 weeks
Wath is the best kombi for Smart-BMS withe Ubox ?
I have a LLT BMS and it works great.
Every smart BMS work with any VESC
Sorry we haven’t tested any SMART-BMS with ubox. Can’t give some good suggestions.
Using LTT at the moment. Works great. Also if you have metr it is compatible with LTT aswell so you don’t have to switch apps to see battery state
Exactly.
