I have both remote over uart and bluetooth available for the app at the same time. My settings are like this: remote to uart on slave esc in vesc tool
In remote: “UART to VESC”: “TO VESC A”; “Bluetooth”: “BT to VESC B, VESC A Occupied By Remote”
I see i think I have the same set up. Basically safe to say that uart a is occupied by remote, and uart b is occupied by bt so basically you can’t use either for accessories unless you disable either the bt or the remote
Yes, that’s my conclusion too. I tried it with ilogger over uart, moment I plug it in, bt or remote stops working, depending on which side I plug it in.
Is it because the BT is trying to act like a control device? I don’t have any problems when I have metr in the other port but bluetooth, nope.
yes, it’s because the remote used uartA. so when you use both UART ports, the remote is not assigned with any UART port, can’t work
Question about 4wd operation. If I connect canbus from one ubox to another, how do I wire the switch to turn them both on and off at the see time? Do I just parallel all 3 wires to both units? Also do I just connect can H and can L? Or all 4 wires
About switch I can’t say, but I connected CAN on High and Low only. I did use a shielded wires thou, so in case I should get signal issues one day I can connect the shield to ground on one side.
Hard to say exactly what happened, but motors locked up threw me off, and then I saw smoke come out of the enclosure, will investigate tonight my settings were 90battery amps and 100 motor
Oh no so sorry
Starting to get a bit scared about mine…
Bro, oh noooooooooooooo. You come out all right?
Hopefully this was just 1 bad case
So sorry man and @hardunclejohn any reason you can think
dude are you ok???
Emotionally. He’s not okay.
A bit scraped up…mostly confidence is shook. Especially after my last fall, broken ankle and what not. Gonna crack it open later. Uuuuuuuugh no idea what could have happened. Battery is in tacked, bms has ash all over it but seems to still be working, at least the blue tooth function is.
If the motors locked up, sounds like the phase side of the ESC shorted.
Yeah this is a ginormous bummer man
glad no serious bodily injury
One motor deffinetly locked up
Wouldnt have happened to been running a METR/iLogger at the time would ya? Stuff like this is why I want my logs running as soon as I turn the board on. Also freaks me out. Glad you’re Okay.
Edit: also not to put METR or iLogger out, but this is why the VESC firmware should have this as a standard feature. Post mortem RCA is critical for finding flaws and preventing them in the future. The fact it isn’t baked in as standard is dumb. (less it is and I’m uninformed)
Unfortunately no, all I had was davega and that does not log
Where do you believe the problem lay
You think the vesc failed or the motors shorted
