@janpom question for you. Will davega work with this thing?
Edit: it does
Edit: it does
I like this alot man, I’m def gonna be bugging you for the updated STL file
Was thinking flip the esc over and stick heatsinks on the bottom of it ?
Are you in the uk ? BB
Hi does anyone know how much current goes to motors want to just xt 3way connector to pair motor and esc up
Thanks
Current to motors is set by the Vesc tool.
Usually 60-85A per motor.
So 30 per phase?
motor current = phase current, kinda.
only 2 phases are active at each switch event. Batt current != motor current however.
Ok thanks, does anyone know where to get bullet conntors I stupidly cut mine off my motors was going to use 3 way xt connectors but can’t find xt 90 way ones thanks
Sounds like you’re looking for MT60 or MR60 connectors?
I’m in the USA, good sir.
@Anubis
https://nexusboards.co.uk/collections/wiring-connectors/products/amass-mr60-3-phase-connectors
opps delete
Maybe I’m going to look very maimed with this but I don’t want to burn anything. to put the esc to work should i put the canbus?
first build? start in this thread: Noob question thread! 2020_Summer
Or start your own thread to get help.
is a update, i change a unity for a spinted but unity dont have can bus wire . i think i need conect the can bus but im not sure
no that is for connecting an external CAN device I think the connection is on the PCB as with all dual ESCs
^wait this is the on/off switch being activated over CAN
Sorry got confused about your question.
maybe for mi shit of english
@luis99945 definitely no need to externally connect the can bus if you don’t use an external can device or want to run 4WD.
thanks
