Holds 21700 12s8p.
Great idea of printed braces!
Mind sharing that unity mount? Love it.
Bracket for using FOCBOX Unity and BMS in a double stack battery.There is space for mounting the receiver of the Flipsky VX remote.There is a hole through which the insulation lock tie passes, so you can attach the VX1 receiver.
It can be used to shortcut wires through tunnels.
3D Servisas FocBox Unity Mount plate required.
BMS uses this.Note that the MAXcharging current is 5A.
https://www.litechpower.com/product-detail/HCX-D127V2LI12S15A.html
Do I recognize this build from @Lee_Wright’s garage?
You talking about the one with the dead battery from a while back?
Hehe nah. I’m in the states. It would be so much trouble sending him my board all the way.
Build here:
be careful with that foam, I’ve had it cause a short in the past, was sitting on bare vesc
silcone vs butyl tape, for serviceability, seems pretty close no?
They’re both serviceable. It’s helpful if your silicone is the clear color.
