empty
2.86US $ 18% OFF|Multifunctional Steam Vaper Ceramic Insulation Head Tweezers...
Smarter Shopping, Better Living! Aliexpress.com
when i search ceramic tweezers online i get tiny little stuff
could you post a pic of what you are referring to
also prob a stupid question but what do you use to hold a wire down while the joint is cooling (especially with lead solder the joint can be flowing for like 5 seconds after you take the iron off)
One comment above yours.
https://www.amazon.com/Yakamoz-Precision-Non-Conductive-Resistant-Anti-Magnetic/dp/B07V6G4V72/ref=mp_s_a_1_5?dchild=1&keywords=ceramic+tweezers&qid=1626162066&sprefix=ceramic+twee&sr=8-5
2nd result in the search
first result on google
ah sorry didnt see
thanks man
ceramic tweezersā¦Fingers, other tweezers or pliers. Everything that can grip without melting.
Wow those look bloody great! Link? Ceramic tweezers of some sort correct?
SG$ 2.28 17%OFF | Multifunctional Steam Vaper Ceramic Insulation Head Tweezers Forceps Yellow
After burning a whole in my soldering iron with a small short
IMG_20210717_220434_7341080Ć1920 237 KB
yo how many amps is that Iron looks like it packs a punch>>
I can only imagine the pant poop moment when you remember isolation is important.
130w iron. Itās a hakko presto I think. Cheap yet great and itās hakko so itāll last. @jack.luis sold me his extra one
Got a question, so i was checking out my solder joints that I soldered a while ago, I forgot that I touched it and ate food. Will anything happen or will I be ok?
If anything happens it wonāt be due to the femtogram of lead you might have ingested.![]()
Stainless steel also works well and draws heat away quickly.
If only Iād found this thread a month ago ⦠Considers stripping & resoldering EVERYTHING
So, I just read through this entire thread to see what Iāve been doing wrong if I have. Lots of good stuff. I do have one tip I picked up somewhere on here that isnāt mentioned.
When youāre soldering a wire to a connector, bullet or otherwise, it will make your life SIGNIFICANTLY easier if you tin your wire BEFORE stripping it. It maintains the size and shape of the wire, which makes it far easier to get it to fit.
I donāt think i had a wire lose itās shape while tinning it. Thatās why we twist the wires before tinning.
Thereās also no way of telling how well the solder has spread out between the strands of wire. Did it go to all sides? How deep did it wick? Youāll know when you strip it.
I should rephrase a bit. Since seeing someone mention that technique and adopting it I havenāt had to clean a ball of solder off my wires, or had any particularly shitty jobs like I was previously. It seems to wick onto the wire a lot cleaner. Iām also rather inexperienced at soldering, I havenāt been using flux, and Iāve been using pretty crap solder that came with my cheap as hell iron, but this technique has helped me out a lot as a total n00b. Also it seems to be quicker and takes less cleanup. Specifically with bullet connectors, which it seems a lot of other n00bs struggle with, it just seems to be a lot quicker and easier, for me with my crappy setup anyways.
Iām gonna redo most if not all of my connections after reading all this, for practice if not for safety.
Edit after reading your edit: this probably would not work well for larger wires, due to the not knowing how well it spread to the sides part. As for how deep, itās probably BECAUSE of the lack of flux, but in the =>8awg wires Iāve been working with, I can pretty clearly feel how deep it goes as soon as it cools a bit.
i eat while soldering in a poorly ventilated room and im alive, however im not very smart
Pro soldering trick: If soldering thick wires to bullets or xt90ās, pre tin the wire before taking the insulation off. That way all the tiny strands will fit in the connector ^^ (This is 8AWG) [20200831_220125] [20200831_220604] [20200831_220713] [20200830_124105] [20200831_220922]
There it is ^^
Ah this explains the concern i had. The method works best to just secure the wire, not to fully tin it.
