Dont I need to use FOC? What else?
Whyâd it do that though?
You most likely need a sensor cable adapter is all. Youâll want them if you are trying to run FOC mode and they are nice in general but are usually the first part to break. You can get the sensor adapter on TB website. My motor runs much quieter and smoother with FOC
Ok yeah, what other modes are there?
https://m.youtube.com/watch?v=Nhy6g9wGHow this is a good watch. Can explain much better than I
Iâll watch it now
I started using HFI in one of my boards because the sensors were acting weird. Like others mentioned, itâs really smooth and I thought the noise would be annoying but it isnât. Definitely recommend HFI since itâs as smooth as sensors, without any sensors.
In laymenâs terms it basically allows the ESC to know the position of the motor and apply a more constant magnetic signal. More consistent torque and more efficiency. You will also not have jitters when starting from a stop. Without sensors youâll want to give the board a push and then throttle up
ok yeah ill def go with sensored
Yes that it will, but only on startup.
Ok yeah, any downfalls though?
If you ride on flat and starting on steep hill isnât something you do often, you will be ok sensorless, not saying it will be as smooth as possible, but will work, on hill sensorless may no be able to start without pushing, and if it is that steep, pushing doesnât help, you stop in 1 m or less
I never killed a sensor, even riding on wet and dirt, put I do an aditional epoxy coat inside the motor
Do you have a pic?
- hall sensors
- temperature sensors.
vesc has a history with temp sensors causing unwanted troubles. [ when working that telemetry is nice. ]
Do hall sensors have some failure mode thatâs worse than oops Iâm forced to go unsensored? an extra failed sensor in sensored mode coggy ride home till you disable them?
This does seem to be the correct answer. ![]()
Not that i know of, i wonder if braking is worse on low speeds. Anyone know this?
Ok thatâs cool. Iâm scared to open my motors though
Opening them is not so bad, just make sure to take note of where all the parts go (especially the small shim washers under the c-clip)
Putting them back together is scary, you have to make sure that the rotor and stator do not slam together with full force, they will want to do this due to the magnetic forces
