I’ve never used sensors and I don’t see why I would start… So my vote is no.
My dual 5570 setup didn’t stutter at all during startup, and although my Elofty DD motors seem a little confused if I don’t push to start, I just have to give half throttle and they spin up fine.
Depends on if you want that smooth start up. You might have to give your board a slight kick push to get going. I prefer sensorless, feels punchier too
Mountainboard = Yes!
Street board = novelty. Nice to have but not necessary.
In both occasions there is HFI which can make sensors obsolete if you can dial it in properly and you like the sound it makes (+ you are forced to use FOC)
i wanted sensors too when i started building, then i came till the conclusion that its not even needed, plus your flipskys dont have a temp sensor so…yeah
If you use HFI you can get most of the smoothness without the risk of broken sensors. I used to be a die hard sensored FOC guy but now with HFI I don’t use them.
Not sure how well it works in the latest release but couple months after first release it just was way to finicky and cogged, so i went sensorless on that board (doesnt have sensors) Wasn’t worth the hassle.
If i have sensors, i use them as long as they work. For me its forever since i haven’t broken any sensors yet.
