i think with that he meant his outrunner motor, not the neohub.
Thinner wire has better copper fill mostly in practice. Sure with thicker wire, on paper you can do the math of circles next to each other and have identical air gap. But nobody do the math for stiff-ass copper wire going around sharp bends multiple times and the patience of factory workers.
Bret + Hummie replying = take cover
Practically though.
Someone is being paid minimum wage to wind these, thinner wires will make life a lot easier and they are more likely to come out better. People like John with the passion and scale to wind thicker wires will likely get a better result.
Scale of economy.
Hey yo fuk u m8
Letās bring shartis back. He will chart the wire thickness to stress ratio.
Iām ded 10neohub
Now my wife watches me weirdly (I mean, more than usual)
You are an optimistic fellow.
If people are thinking that these hubs are going to be as good as hummieās they are in for a disappointment. Iām sure they will be great but you canāt really compare a large production commercial offering with the sort of thing John is able to put out.
Lets be real about that.
Edit: I will buttboard race @BigBen in a straight line on his Hummie hubs though, for science.
Fixed it for ya. ![]()
Hummie has been replying for a long time. Iām scared.
Skin effect happens at a high frequency. I forget what frequency but especially with a hub motor I remember it not being high enough to produce skin effect
14 awg is huge. Considering the size of these motors and assuming maybe n48 magnets if single strand and even wye terminated, which these donāt seem to be, I bet it would be maybe 19 awg to get a kv around 75-80. I was using a stator I think maybe twice as long and with thick steel behind each magnet, which was curved and much wider almost full fill and an air gap as low as .2-.4mm and would do 17awg and also wye to get 75kv. I did them almost all the same like that
U donāt find single strand winding or wye almost anywhere because machines donāt do it. Sometimes u can get more copper on with multi strand but almost always a single strand rewind will be not only more copper but the coils can be organized better so more inductance produced and easier to organize neatly leaving minimum gaps between coils which trap heat. Most inductance for least electrical resistance being the goal.
Winding thick wire isnāt hard and I now do 16 awg. U canāt put it on like in this pic above though and u need more leverage. I tie one end to a doorknob and pull it on. Very tight and when u figure what wire fits it just fits. If I didnāt do it just right it wouldnāt fit. Like a jigsaw puzzle.
I used āheavy buildā wire. It has double the insulation. Iāve never heard thinner wire having less insulation just because thinner. The insulation is pretty fantastic as long as ur stator has not even the tiniest bit of bare steel otherwise itās likely to scratch and short and big waste of time. U can really deform the wire no problem regardless of its size and msw wire told me for some of their wire they shape it after putting on the insulation.
Square wire would be ideal except insanely expensive in anything smaller than 16 awg and when so thin it ends up being too hard to stack it and ultimately it ended up worse for me every time I tried it. But if 15 awg or above it could be great. Not only because itās more square and less voids between( itās a bit round) but because u can stack. Otherwise with round ur forced to lay it on in layers along the tooth going bottom to top then back down and up again or it collapses.
Yeah that too⦠hubs are a tool like outrunners are a tool. You wouldnāt pick up a spanner when you needed to hammer a nail in. Yeah it would work but youād be an idiot hitting a nail with a spanner.
These are for fun cruising and chuck around shopping cart boards, simplistic builds and for the fun of trying something different.
What frequency would we be? This above is 12 tooth. @BluPenguin. I think the switching frequency thatās adjustable on the esc is irrelevant and smoothed by the inductance. Pretty sure then it would be related to just the erpm
Ha. Is that a real tool? Good idea make everything also a hammer
I no say is 14awg copper. I think maybe you not understanding my word. I say cable for using is 14awg.
Why make so many word posting here.
Aaaaaah ok my bad. Language barrier. Iāll amend.
Yeah, they call it minerās wrench or something. Adjustable with a hammer head.
And yeah I was thinking eRPM, 60k on vesc 4 and 100k+ on vesc 6? Shouldnāt that be high enough to induce a tiiiiny but of skin effect difference?
Weāre all under quarantine and bored so we want to fight over the most useless things.
