80100 x 4?
Some inferior designs that don’t have smart functions
No option for no? Did @Halbj613 get your password?
Let the man finish a thing or two first.
Yes, but not for a skateboard. And not soon. Back burner project
Just a reminder this exists
You can send your 'No’s my way.
Just collecting info for the man… He’ll be done with his current lineup of work by mid January, soooo.
It must be Jeffwu.
you don’t need it. If there’s a boot loader on the pcb the end user can flash it in Vesc Tool or FocBox Tool or BLDC Tool.
The bootloader gets programmed into the micro
oh I thought it was standard shit that came on the chip from the factory. my bad.
You know, I think you can get chips preprogrammed from some suppliers, so that actually may still be an option lol
We program all STM chip before make assemble.
No, you are correct. There is this thing called the “Device Firmware Update” that no one seems to want to use!
Vesc tool has no support for STM32 native DFU.
From factory is ok. But need to enable DFU by short pin on PCB. Then can flash use STM tool. But for mass production is better for flash before SMT or making jig for flash.
I was planning on connecting a DIP switch to the boot pin, and then using the USB DFU, as the connector for that will be populated for normal operation anyway.
But first choice will always be having the distributor, such as digikey, preprogram the chips for me.
30 posts were split to a new topic: Open GPL Discussions
Jeff, do you have pictures of the dual v6 pcb?
Not yet. We make 6 layer pcb design to make small as can. I share when ready.
