Rusins' 1st Mountainboard | Trampa Holypro | Jump drives | 12s8p
Finished the motor wire extensions:
Figured out the sensor problem; vescs weren’t set to use 5V. There’s a switch on the inside:
Tore the griptape off the board:
Cleaned up the leftover glue with WD40 and paper towels. Nice!
Then I dremelled the Trampa logo off the wings:
Drilled a lot of holes for the wings:
My board really looking like Swiss Cheese now:
Routed the wires underneath:
I need to leave the wires long so that I can still open the box. In hindsight I probably should have added the cable glands to the long side of the box (then I could fit all 8), and route the wires under the box to that side. Well, since my box mounting pattern is 8x8cm, I could still rotate my existing box, but the wires aren’t long enough :confused:
Also, the 4 rubber anti-vibration mounts move a bit more than I’d like them too. Maybe I shouldn’t have gone with the M5 ones. I don’t feel comfortable using my box handle to lift the whole weight of the board with these. :confused:
Anyway, added butyl tape above the bolts on the inside:
And used velcro to attach all the little bits and bobs. Still using my 12s3p travel battery, with some foam blocks around it. Gonna take it for a spin tomorrow :slight_smile:
