Waiting for the Arduino to arrive in a few days, does it work with the 5.2 firmware?
Yes, it does. Good luck
Hey man, any chance you can make it work with the 5.3 firmware?
I have been using it with the 5.3 dev firmware and that was working, I’ll have to see why its not working any more.
It’s the single reason why I’m still on the 5.2 fw lol, can’t live without it now
Any luck?
No, I just updated my controller to firmware 5.03 to verify that it doesn’t work. I don’t know what changed to make this display stop working, I’ll have to look into it some more
Ok, I found the problem. It seems the packet the vesc is sending out has changed, it is now 1 byte longer. For now, in the file “vesc_comm_standard.cpp” you can change line 24 to
_max_packet_length = 80;
Then it will work again.
I made a new release on github as well now.
@Charclo if you don’t mind me asking, what buttons are you using in this photo and is that a 3D printed button housing?
Made a lite version of the display without buttons, looks a bit cleaner and compact.
I’ll post the files if anyone’s interested.
These are the buttons of an old ebike display. Some bafang displays use the same buttons. I think you can find them separately on aliexpress
Nice, I also really like 3d printed case. Can you post the files for this?
@VodkaMan I love the minimal design! Can you share the files?
I’d love to see which enclosure everyone is using.
Hello. I am quite new to this but would it be possible to make this work with 5" inch TFT for example . I would like to put something like this on my motorcycle . A bigger screen might offer more real-estate for more Info instead of changing screens !
5” might be difficult, as the resolution of these seems to be a lot higher, but it would be possible to change the code to support a 3,5 inch display. The screen updates will be slower
dope gonna try to adopted your code into this device open smart watch with 37mm display! It fits PERFECTLY into classic scooters round display.
Than plan is to make first screen to look like classic VSETT / Minimotor screen theme
- incl switching modes 1/2/3 (because police knows to put it into 3, so it has to work and set VESC limit 15-20-25kmh)
- Than make the custom screen that would show all we normally want to see on VESC and may be 2 power modes on same button (500w 15kmh / no limit)
- since it has accelerometer built in, I think I could add ALARM mode (Throttle input is disabled, if moved during ARMED maximum regeneration will be activated and Siren mosfet signal open, until 5sec with no acceleration changes, dead band set reasonably to avoid wind triggering)
sounds fun
I wish I could code well… could even add simcard and GPS to it or VSETT RFID as it works dedicated over UART +12v and ![]()
4153412281
I’ll buy 10
Ready? Needs 7/8 handlebar mount. I can CNC or print
Pauls 3d open source watch? I have one that could see a new life as an eskate telemetry watch. It supports bluetooth connections too.
