That would be disappointing, especially on a long print. Was it plastic in the threads? Maybe run a tap through them?
It must have been the iron being too hot and melting the inserts or something because they wouldnāt take at all. Luckily I tested them in a junk print first
idk. iām a fatty. so I donāt go there?
though i recently lost 30lbs. I figured out itās the best upgrade to all my boards.
Whatever, fatty.
at least I donāt bend my trucks. fatty.
I experienced this at first too and turns out the first thread was getting crushed a bit by the tip due to the insert not heating up enough. Letting the tip rest on the insert longer and making sure not to force it solved it for me.
Whatever Fessypoo youāll always be fat to me.
Just how I like em
Whatās your new top Speed after the weight lors?
2G more accel.
@Evwan
Thereās fishpaper on/under/between all necessary connections lol.
This battery is as transparent as possible without missing out on any of the safety features ^^
None between the cells though?
Are we starting esk8 finger boards now?
There is. Itās just not super visible. Itās a narrow strip of fishpaper + the inner circles of the cell rings. Itās like that so the hma sticks to the cell and hold everything secure (:
This is from some tests. Itās done like you can see here.
Teach me how you made that image a clickable link!
when u finish upload an image, there should be an image id, highlight that and press the hyperlink icon, add the url and confirm it, it will make it clickable
e: the only downside is that, u can no longer click the image to enlarge it to zoom in, unless u open the image itself in a new tab
I wonder if it was assembled with Loctite
i would expect probably not, as @jack.luis pointed out at the bottom of the image
Ahh, missed that part. He needs to put a disclaimer to remove the axles from the hanger and reinstall them with Loctite. I believe these were the ones falling out on people
loctite still wonāt help with the wheel core delam issue tho
and the fact that dex is lil bitch that cant handle criticism
