Yoooo these inserts look sick, but how do you install them exactly??
YES
Dang, I would definitely go for warranty
the purple makes it look erotic
I think you heat them with a soldering iron and press them into a melty polymer, like 3D printed stuff mostly.
I mean, if you are into CNC⦠it may well be
In between the wheels are 25mm
The ones on the inside are actually the falcon gear drive adapter
Tires look odd because you have to deflate the outside wheel to fit the wrench to tighten the wheel on.
So how would that work as inserts into a wooden deck?
Itās not meant for wood, you melt it into 3d printed parts.
We could do that with your Enclosures. I think @kilow used them on his( not sure if itās for ubox or not)
Oh weird, so he put the inserts in the enclosure and drilled through the deck to feed bolts through all the way? Why not just use locknut itās if youāre gonna do it like that?
I think more so for attaching a lid to a esc enclosure. I wouldnāt bolt it to a deck with those.
Ahhh ok i totally missed the context of the original post lol
Nah, I used hex standoffs. I was interest in what at good inserts. Now I know
Those are just m3 nuts. I drop them in with a print pause and they get embedded
Slick shit dude!
Oooh thatās a really neat trick Iāve never considered ![]()
Threads hold better than just plastic, especially if you are using them often. The low profile m3s donāt take up too much space either.
Melted in inserts might be stronger however
Idk what my problem was but 3 out of 3 melted-in inserts fucked up the threads and wouldnāt take the bolts anymore without crossthreading. Maybe I was using the wrong iron tip.
