Looks like a cheerio on steroid
We have the same arrangement in my place now, I donāt know how I lived without it before
3d printing testā¦getting good results now
Ellegoo Neptune 2, Prusa Slicer w/ ender 3 slicer printer settings, Prusament Galaxy Black PLA with Creality prusament filament settings.
Make JayKay trucks but they use classic skate wheels and trucks, ultra unsuspicious
Looking about as good as it can be, nice work!
Thanks man, its just about were I want it. Fun things to come
You can, just took some tweaking and a little patience to get it right. Biggest recommendation I can give besides the obvious of a level bed and correct setting is⦠Have a CLEAN printing surface. Make sure to wipe it down well with some Isopropyl Alcohol, mild soapy water or even Windex can work. But, a clean surface is a must. I was having a lot of issues until I used a clean bed, either metal flexi plate or (even better a piece of glass) will work, you can use the glue stick but, with a good clean surface you shouldnāt need it. Hope that helps!
Yeah I wipe the bed with isopropyl alcohol before every print. Adhesion problems are a thing of the past.
I just have a lot of tiny layer shifts, and lots of stringingā¦
What printer and slicer are you using?
I have a Prusa MK3S+, and I use prusa slicer. I pretty sure that its just the garbage filament that I currently have, Prusament Filament works miles better on most prints. Its just so expensiveā¦
Sounds like you should be fine then. Filament can for sure be your issue, Prusament isnt too bad if you get it directly, itās double on amazon. Yeah, I have Prusament PLA, Amolen PLA(30%woodfill), CCTree PLA and some Overture Nylon. They all print well with the appropriate stock filament setting provided through Prusa slicer. The wood I get a slight stringing and the nylon is a little as well. Otherwise they all work great.
Do you use an enclosure? So far I have only printed in PLA as Iāve read that for Nylon and other thermally more stable stuff you need one.
bruh wtf. Did you jump with it or something?
No enclosure, may help a little though as I have a little consistency issue but, still pretty clean prints
So fresh, so clean.
dang. my oil slicks definitely did better than that. bad batch?
How is it when I bend trucks everyone is all āhaha fattyā but the pretty ones get benefit of the doubt?
If I did jump with it, shouldnāt these trucks be able to hold up to that abuse?! I didnāt jump it, but it did smack a 3 inch concrete lip at 20mphāish after my buddy under estimated the strength of my breaks compared to his meepo. While he was falling off, he must have engaged that trigger.
