wow dude.
that looks nice!
looks super heavy duty?
what are you working on?
esk8 hot dog stand?
wow dude.
that looks nice!
esk8 hot dog stand?
I’m not sure if heavy duty it truem we shall find iut haha. it’s an 8mm alu sheet that i cut down the middle to bend it into 30 degrees for the haero deck, then i filled that cut with epoxy and painted it. i used 2 pillow block bearing and a shoulder bolt for assembly, this way it turns freely. for the mount it self i just drilled the holes slightly bigger to accomodate 2 bushings. i hammered them in because the only function it to hold it straight on the shoulder bolt. then the usual spring that joins the trailer pops in and voila. i’ll use it to tow friends, but also take the recycling and rubbish out (we have community bins, not personal bins where a trucks comes a empties it every week)
Me too! No, I’m pretty light… Hell no! I’m gonna keep going hard! 🤷
Yepp ok so something for science??
All I heard was that you’re building a shaggin wagon.
Reacherrrrrr
Can I have the link to that enclosure you are using? I have been using this for my battery but this one is actually too large for my 12s4p. Might work for you tho.
Sure! I actually had that same enclosure you linked saved when considering options, but the one I purchased is about an inch taller than yours. Still, it’s not tall enough, I need one that’s about 4 inches tall :/. Mine may work for you since its a tad shorter length wise.
Here you are
That’s a cool helmet. Yours?
Lol no
I see. I didn’t realize it was so tall. mine has an internal height of ~2.5in. this enclosure is longer so you might be able to mount the esc next to the batteries instead of on top of it. what’s the dimensions of the esc and lipos? the internal dimensions of the enclosure is 7.5in 11.5in 2.5in.
The VESC won’t stand next to them, it’s a tad too tall.
How do you plan to mount a soft case like that?
Same man. There’s a chance I crash going 30 and the road sheers through the hard case and cuts into my lipos, but I really doubt that would happen.
Im more worried about a car running my shit over and it exploding under them though.
Ohhhh I see, yeah that would work great! Too bad the fsesc is huge.
I do plan to scrap this ESC and get a 60d soon though.
