We sure did. This makes the remote way more expensive, but safety is above anything a fancy screen could offer.
The remote has been tested since winter of 2020, including visits to huge antenna towers, deadspots near scientific buildings, group rides with mixed remotes. Not a single delay/disconnection/interference issue has been registered so far. We have quite a few tester testimonials for that.
Awesome. Totally understand. I like the wood look, itās pretty neat. From what I heard before I think you guys are using the same high quality actuator-trigger that the OSRR had? I didnāt keep up with all that very well at the time
Nope, this was on the beta tester in question few months ago, whom has designed his own with advice from us. So now itās a totally in-house made 16-bit hall effect sensor thingie.
The new aluminum thumbwheels can be seen here:
Also, the main priority of this remote is being a trigger remote. The thumbwheel came around because of engineering prowess of some testers. Stay tuned for the trigger remote pics next week.
Indeed it is, I know next to nothing about electronics, but what I do know is I rode this remote through both spots where my puck would drop out, no issues. This is also the same remote that gave me the confidence to push my board harder then ever before
49mphā¦would be a bad speed for a cut out. @KAMI_Boards keep up the great work! Really exited for the production batch!
Yeah my current remote makes me ride more conservatively
Between that and my one bergmister tire that has wobble, it limits me to about 35 before it gets really sketchy
Tbh cutout at anything above 20 is scary
The way the Maytech cuts is weird too, it continues whatever the last command was that you were giving it. If you are neutral and it cuts out, it coasts, accelerating and it cuts, stays accelerating at same rate, and likewise for braking.
Better than the hobbywing one though where cutout = full brake lol
@ShutterShock Yep, iRemote has a 2nd channel that can be used for lights, controlled by a trigger style extra button on the side, and that can be programmed for Cruise control, safety switch or reverse toggling.
It has proper implementation of Frequency Hopping, protecting it from any interference whatsoever.
A trigger style version is also coming up soon, its circular shape makes it to retrofit into many other enclosure designs.
The production enclosure will be made out of MJF, smooth, super strong and looks nice.
The beta remote I had, had programmable options for how you want your system to handle a cut out in case one happens. You could chose between neutral coasting or soft brakes. I took the remote many places, as busy as San Francisco, all over Oakland, including Bart, hills and mountains, forrest, Joshua tree dessertā¦functioned well in all of the placesā¦even took it to Bombay beach place is a bit scary lol
Your referring to the Kami remote correct? Just making sure I mark the correct one, im probably gonna get both anyways because they seem like they are coming for the puck remotes throneā¦
Man the remote scene is something to watch for sure⦠within the past year it went from pretty awful to you three producing insane top notch remotes that will hopefully solve all our issuesā¦
