FUB (aka imperial / avoirdupois) to me, is just like this, but with different words:
ā¦and this is coming from someone in the USA. I can only imagine what other countries see.
oh i read this one before, i did find it very funny. its all in what your used too.
It depends. I can definitely say i stripped many phillips heads, but never a flathead. I do however struggle to keep the screwdriver bit inside the grove while turning, especially with an electric screwdriver.
use a sanding disc to cut the groove deeper
thatās not the problem, rather the bit moving to the outside/sliding out.
also at that point i might just get the correct screw ![]()
exactly, u should
Basically this,
but it get even worst when you have to make a convertion: no other choice than to use some random web app,
Then you hit your head on the walls until.you understand that the dot and the coma are not interchangeable and wonāt be working the way you intend to
Embrace the Metric we use both the imperial and the metric but it depends on what we measure! Or weigh or scale (Canadians will understand)
I do, I really just say that stuff to get ol Brian @b264 worked up
Oh I fully expected this to be the case⦠hence why I already laid down the groundwork to produce a suitable gasket/riserā¦
What deck is that?
Always looks so clean at that stage in the build ![]()
And another one gone and another one gone
Another one bites the dust ![]()
Its a beauty
Oh yeah! Now I remember seeing that a while back (and lusting after the Hi5ber Raptor). I havenāt been keeping up-to-date.
Iām loving that interface between the enclosure and the deck, @janpom. Youāve turned an issue into a really useful feature! Nice work!
Damn 2 steps ahead, nice!!
the dream team right here ![]()
Enjoyy
At the risk of being pedantic, the term flat head is being used confusingly here. Flat head is the head shape, whereas as slotted is the god awful drive type.
I only feel the need to correct his because @Savage1 and I had some unnecessarily long and vexing conversations when we first started designing our mounts due to my ignorance of this distinction. He mentioned using āflat head screwsā for the handles and I too nearly yaked.
Thanks for coming to my Ted Talk.
I appreciate this. I grew up in a philips/flat head family but that was only for describing the tool.
The phrase āflat headā became falsely synonymous with the screw in the early 90s when children would fetch screwdrivers for their parents.
I went for a Wikipedia vibe.
Not gonna lie, I had to look that word up
