If you don’t understand, own one you’ll never, Lacroix ?
What are you currently using for covering the deck?
Looks like harley davidson designed that shirt for lacroix, surely that is homemade.
I should make one that says butt plug instead of lacroix😂
Signwriters vinyl
Looks artsy :slight_smile:
Is that outer contour a silicone thing? What is the purpose of that?
It’s a bead of silicone to act as a dam for the silicone that I will be pouring over it tomorrow and the coming days.
If you wanna follow in detail, i post most of my shenanigans in my workshop thread
hmm seems that could easily be picked up local for me
Love those 6’’ nylon tires :wink: which ones are those hangers?
:slight_smile: I never noticed they said Nylon on the sidewall !! They definitely feel like rubber :joy:
The hangers are basic TB 218 (caliber clones). Today was just a ‘put together’ day to see if stuff fitted/lights worked and I still need to connect drivetrain electrics.
They definitely feel amazingly soft :slight_smile:
Those hubs need quite longs axles, cool that you managed to fit them in.
yeah they are right on the limit. Needed to make some 5mm spacers (ground down some 8mm ones) to get the fit right.
Wasn’t that delivered directly to Renee?
It was, yes.
But she’s busy working while I’m handling our meme department.
The cutout for the LEDs is killing me :joy:
Well of course. How else would you see them? It’s not like you can remove the logo
What material did you use on those ? Have you tried jumping on the board to stress test it, many attemps of these kinds of brackets bent
Why don’t use something like a copper bus bar? You could also spot weld nickel to it. Because it looks like a possible fire hazard :smiley:
Background photo credit to @pdscunha
This looks great! I’d definitely pick up a copy before boarding my flight to PDX
