Do ittt. SOSO worth it. And if you do it and then decide you donāt want it Iāll buy it off you =)
If only it was a real magazine
, just made the cover for a graphic design class
Thank you @glyphiks @MysticalDork @b264 for your help
I prefer the smaller hand-squeezable containers, but thatās definitely the good stuff
I prefer clear because if you ever need to work on something, you can cut into it and see whatās under the surface.
If I used it on the exterior, Iād probably like black, but I donāt use it externally, I use epoxy for that.
What in the ClockWork Orange is This?
They are made from 2017A alu. Yes I did jump on the board to the point of hurting my foot but thatās not a real test of any kind for me. I saw that @dani (if Iām not mistaken) had one failed try and no others. For the summer the are going to be 4 of those boards tested and Iām thinking of some kind of destruction test and that should show me a weak spot.
How does one aquire a M1 with a motor ??
They will be on the site very soon but theyāre technically ready to ship
Do you know what is soon too ? Payday XD do you have a price for them ?
Motors are $110.
There are so many configurations that I canāt give a price without details.
Next week for AT drives. The street ones are ready now.
That is gonna be a sexy build man. Printed enclosure?
Is that a sender or you
Gorgeous ![]()
Lol, sender would be much better! Itās, air brushed, and my epoxy skills are, letās say, still in the learning phaseš
Yes. I would also like to know more about this top box @ShutterShock
Yep itās printed! I think Iāll make a build thread for this mountainboard soon.
The enclosure is all pla right now but I have nylon that I intend to utilize. Itās quite strong now as it is.
The lid and base attach to the walls with very strong heat inserts, by spreading out the screws, it helps make them sheer walls, strengthening the base and lid. The base has an X as well for increased strength
I custom designed it for this build, as I will with the esc enclosure. It can fit up to 12s8p of P42a with a bms
Cool. How will you fix the battery enclosure to the deck?
Damn dude, I want it
good stuff.
