Yes please!
Granted I have a bigger verision of the speaker, but I found a youtube video of dissasembling.
Fortunatly, the compartment for the battery was large enough for 18650
Is it glass frit? It seems lucid clear grip spray to me, can it be?
Itās frit Hereās the One of many tutorials he learned from @glyphiks and @rosco @PedroMcJimenez
Cool, thanks. Doesnāt the sanding ruin the artwork of the deck, or is it made afterwards?
What sanding? my method is the minimal sanding method
I just used the lucid clear spray on a deck to avoid sanding
Please let us know more details about your invention kind sir.
On my Wowgo 2S, which attaches the motors the same way, the axle got loose in that part and it started rattling after about 1300km of rough riding. And I am fairly lightweight (about 75kg)
The video is me moving the motor, to demonstrate where the noise is coming from.
The screws were in really tight, so there way no way to tighten further. It was still an easy fix though, I cut a little bit of material out of a beer can to make the fit tighter, the noise didnāt return since then. Though I havenāt ridden much since fixing it, maybe 200km at most. When the noise will return I will probably jbweld the axle in.
So the axle was moving up and down in the truck slot?
Yes, exactly.
I had the same thing on my brand new wowgo 2s 3 years ago. I put electrical betwen axle and truck.
This seems to be a truck issue as i swapped mine a few weeks ago and it didnāt have that problem. I assume casting tolerances are the cause.
Can be seen here in the video i did minutes after receiving the board.
Didnāt have the issue with the meepo truck as well.
Yeah itās a truck issue. For me it only started happening after a certain amount of distance covered. I remember riding on cubblestone like surfaces that day though, after I got off the cubblestones the rattling noise was really loud and I was legit worried if I will make it to the bus stop. I donāt remember hearing it rattling before riding on the cubblestone like surface that day.
@Anubis I here you have Connections at meepo I would like to go through the forum instead of buying from the sites if youāre interested I would love to do a group buy this is what I would want
@xsynatic you got me thinking on these hubs do you think 4wd is doable your thoughts thanks
it is.
Even sold by meepo
Iāll check it out how is their ESC?? and I would want a nice 12s4p 21700
