I tried to make this one gears but the Boardnamics gears I have arenāt the right ratio for 130mm wheels and I wonāt entertain any non-steel options anymore.
10s and the right kv will make it
Low Kv motors donāt work as well on HFI and unsensored.
Chains are the answer, I think.
Itās been there a while⦠Pretty dumb
@bboybowzer You can order the good tape measures online. If you try to buy one in-person, they only have those shitty all FUB models.
You donāt like harbor freight? Haha
The day I went to Home Depot to get a tape measure, and they had over 75 all-FUB models and zero that could use modern measurement systems, and I had to leave empty-handed and order one online anyway ā thatās the moment I decided that I donāt care if they go out of business and Iām doing all my shopping online from then on.
Itās outright disrespectful.
@wapkoen Where did you get these?
Hey the HF measuring tapes are almost always free with any purchase, and Iām not complaining about free stuff.
Even free stuff thatās 2.54 times the scale you need
free stuff cost the most, and usually it aināt worth it
I wonāt dare to take a picture this close so you guys can see how shit my layers look ![]()
I made them. I was having concentricity issues with the sprockets i bought initially. Hopefully these fix that issue
Wow, this looks awesome, are there stls available online?
Are 8 teeth sprockets even okay to run with chains? Iāve read that even 12 is really pushing it.
I just go by the mantra: if Jens sells it. Itās OK.
Higher tooth count fucks up my ratio. And I donāt want more diameter on the wheel sprocket.
Yeah, search for GT2B on thingverse
What is the gear ratio you are able to get here? What are the wheel sprockets?
And what wheel hubs?
Iām running 10/70 on 225mm wheels.
Iām using #25 chain.
But have been pondering getting heavier duty chains.
I chewed through this 9 tooth pulley in about 2 monthsā¦
Is the torque at 7:1 ripping your shoes off with 225 mm?
