Who not order some quality belts instead of ALI express junk? These have been working great for me, and I was a belt breaker before I got them. https://ddglobal.com
DD Global ones are breaking too.
Yes. There is only one all-steel gear manufacturer that I know of, @Boardnamics, and they donāt have a ratio that works with my wheels.
Are you running idler pulleys?
Noā
LoL
i would try to contact a local factory/manufacture who would cut you a bit from one of his rolls instead of trying to find the right size one from the net
LoL thatās easy to say but without links or phone numbers, itās not so easy LoL
Also what are these local manufacturers you speak of? Iām in the USA, not China
Maybe could find a local reseller
I mostly jest, but this is partially based on truths also
i dontā know if this helps:
Itās time to join the chain gang!
I can make anything your heart desires Brian
for the right price
ah gottcha
true that, not manufacturer, but resselers for factorys furnitures,
most of the time if you actually pop up there they will send you the ridiculous quantity you need as a private person without making difficulties but they have stuff you wonāt find in consumer loops.
also, would this work ?
pitch is 5M, didnāt check the profile heights but from the visual i canāt tell the difference
also i think the one @XTLA used in his Xnow build where those ones :
but it seems like PU ones (with kevlar cords ? canāt see it written)
What about those 300mm wide belts you got?
das a wide belt, wider than most supercharger belts
and top mount gang
Have you seen the photo Iām referring to?
No but Iām imagining a belt thats a foot wide
BEEFY. Whatās the story here? Intrigued.
I had a local supplier that could cut in any width you want
How I know that? Because the guy that was cutting must have been blind and missing an arm and a few fingers on the one that remained while using a kids scissor, a 15mm belt was 17mm in some places, 9 in other and só on
You could run two 9mm belts in parallel or even 15+9 or even 15+15
