10s3p of some old 2.2Ah cells I had with a 20A boost converter to output CCCV. Right now its set at 42V but the output can range from 42-100V. Charging current is set to around 8A which should charge the lipos in my little boosted clone in 40 minutes.
Its mainly for when I’m riding in town with my friend. He usually gets 12 miles out of the 5Ah pack in the board. We usually take a break and eat something and by the time that’s done the board should be charged. Its pretty small and light. Not designed to be a charge and ride but could be with a strap and a 90 degree cable on the board side.
At 8 amps current you might want a fan in there. My experience with boost/bucks converters is they get hot. And like to burn out in enclosed spaces
How do you like those motors?
As a heavy user of 5Ah packs, that’s a lot of miles. He must be really light. 7-8 miles is about where I top out when riding gentle. 5 miles riding hard. But I’m also fat.
I am hoping to get away without a fan for now, the heatsink on it currently is pretty beefy just gets a little warm. Its rated for 1200W and I’m only using ~330W. Also with only a few volts difference between input/output it is fairly efficient.
I have in my metr logs from my trampa (my ride) our rides max out at around 11.85 miles before the lipos in the other board hit the 3.5v cut off. He weighs around 185lbs. The board is dual 5055 geared for 22.5 mph with 45A total batt max running 2x Zippy 5s 5Ah lipos. The area is mostly flat which definitely helps. I believe it was getting around 16Wh/mi when he rides it and around 12Wh/mi when my sister(significantly lighter) rides it. Maybe its that hard as a rock urethane…
Or…
Rides mostly downhill.
I love those roads that are downhill both ways :rofl:
Or…maybe someone is not lean…
it looks like they are using the cheap welder tips not the nice Kweld ones. Wonder if that is for good reason or what.
if I did this I would try to use them but perhaps they are too large/the rounded ends need to be rotated because they don’t get obliterated like the smaller ones and more need resurfacing than replacement.
this motor ain’t bad, it just rebrand of APS motor
:joy: Got used to it :rofl:
Maybe the benefit is consistency since the tips are cylindrical rather than conical, they would keep roughly the same cross section as they are used. Keep a few on hand and treat them as consumables.
yeah that’s pretty much what I thought. I’m sure with perfectly even pressure you are less likely to get sparks and wear down the electrodes maybe.
I’m sure it works fine the Kweld tips are meant more for using by hand anyways
@tatus1969 any input?
Okay, thanks! I guess that means that they need to be battlehardened, so i pass for now.
Exactly. I had played with tip shapes, and a soft rounding achieved the best electrical contact considering that the material softens and dents during the pulse. The other reason of having a conical shape is better electrical conductivity of the thicker copper rod, and less heat generation when compared to thinner tips.
oh that makes me think of a welder attachment for a 3d printer get it to do the welds automatically for you
if you bolted the battery in place maybe you could?
it’s called a CNC spotwelder.
you got a link to see one
not interested in making but just interesting in seeing
also do they work well?
1st google result
