Raptor owners scavenge grounds
It guess it depends on which version you tore apart. But on the inside ( Kingpin side ) There should be a second injection molded ring to keep the thing together. In first versions the centrifugal forces on the Inside made the PU extend and become Oval, this extra ring prevented it from happening
bump
I’ve torn apart the first version of the wheel 90mm heres is the demolding
Thanks for telling me about the second version of the wheels I do not own a press atm so I need to figure something out
I did some digging. Look at this :slight_smile:
No fucking way dude, nice!
Yeah the Labeda formula Raptor Outhweels rule.
got 1400km on my sleeves with no chunking… or anything. Almost as good as Onlin Popcas… - little closer to Poppca foruma would last for ages. provided such changes wont impact how the wheel responds to heat
Still available?
Cleaning up old enertion stock, wheels, hub motors, etc.
https://www.ridefatdaddy.com/product-category/parts/enertion-parts/
Off-topic but what keyboard and keycaps you got there?
I sadly can’t tell you. The pictures were taken from the person storing the enclosure for me.
it looks like the NYM96, but im not sure. Keycaps are too common to identify :joy:
Yes I still have them
Where did you see this?
This is from last year. So I had to ask around and I found a supplier thats willing to work with me on wheels. I have a step file design of a wheel with the inner retainer. That will reinforce the wheel from high-speed expansion and ovaling at higher temps.
I think i have someone who wants this sry did not realize you were selling it before.
What is a an Enertion Unity BMS? - it’s just a BMS - works on OG 1.6-1.7, and many other brands
Also your discription on motors are not true. Only 2.1 Motor (if the truck is included has a Heatchamber (Copper vapor chamber)
The 2.0 Varriations with 10mm Axle… have a 10mm Axel and no integrated heatsink. (however the hangar does cool off better than the 2.1)
I thought the 2.0 were the black motors. Did they switch to the silver before 2.1 or is it not the actual photo?
There’s a few versions, 2.0 had Black Motors 8mm . Then 10mm silver but still with axle nut > then the 15mm with cooling (there are 2 between im skipping)
The Blacks were the most effeciant overall.
Since most quotes for custom orders were expensive. I’m waiting for my new lathe to come in so I will be able to work on the finish of the wheel when they are done casting.
