The light gray path around the perimeter is shitty gravel and rocks but the light gray going all around the middle of the park is a mixed terrain path that is mostly low cut grass with some mild hills, dirt, and rock features. Very mellow to cruise.
Some range testing with 12S4P P42A, 2x 6380 motors and Bergs. Charged to 4.15 per cell. Some of this was gravel roads so not ideal but the board seems to have a lot of usable range!
So lets talk about the FS 6384s… Dayummm! I got a set off @A13XR3 last week and just got around to a test ride… I hit the 2 biggest hills in my area and literally fucking crushed them all the way to the top… With no fade in power in sight.
Now i can’t tell if the only factor is that my balls are bigger now or also the fact I bump the motor amps from 60 to 80… The battery max didnt change as its set for 80a max… Just that i kept my maytech 6374s at 60a based on their ratings…
With that said I initially kept the motor amps at 60 to start to see what immediate feel was like upgrading motor size… I found the 6384s more sluggish off the line vs the 74s which was why I bumped up the value…
it fells like when I upped from 55s to my 74s… more consistent pull… even if i bump to 100a for fun the battery is capped at 80a so wheres that extra “fun” comin from? =P
Even tho your battery is only supplying 80 amps. The way electirical current saturates the stator, you motor will more often then not retain more current then your battery current setting.
Probably killed a snake today, was riding on the woods, no trail, and there it was, only saw it when it was half a meter, I was really slow but didn’t know what to do, I don’t have reverse enabled and if I didn’t want to find if it was friendly lol, just gunned, snake was around a meter long
Hopefully it is ok, is was a layer of soft sand with lots of leaves above
