Righto cocks! We have compendiums for wheels, motors and decks… but none for pulleys!
Gonna make this a wiki so please feel free to add into it!
Please include tooth count (TC), pulley width (PW), core type/hub compatibility, attachment type (pressfit or bolt on), whether or not the pulley has it’s own bearing, photos and a link to where we can find them!
Urethane Aluminum Pulleys
Mfg
Teeth
Width
Core
Notes
Boardnamics
36t, 40t
16mm
Kegel & ABEC
Press Fit
Boardnamics
44t
16mm
Kegel & ABEC
Press Fit
Dickyho
36t
12 & 16mm
Kegel
Press Fit / Bolt on hybrid
Dickyho
40t, 44t
16mm
Kegel
Dickyho
36t
12 & 17mm
ABEC
Dickyho
40t, 44t
17mm
ABEC
Savage1
36t, 40t, 48t
15mm
Kegel
Press Fit
Torqueboards
36t
15mm
Kegel
Bolt on
Torqueboards
36t
15mm
ABEC
Bolt on
Urethane Plastic Pulleys
Mfg
Teeth
Width
Core
Notes
3d Printed
32t-50t
8-15mm
Kegel & ABEC
Bolt on
Print in PETG or better
BKB
40t
15?
Kegel
Press Fit
Injection Molded
AT Pulleys
Hybrid Pulleys
Motor Pulleys
Does anyone know how to make these into tables?
nsteph
June 1, 2022, 12:39pm
#3
Thank you! I was losing my mind last night trying to search and compare differences in pulleys and spacing and what!
Blank
blank
blank
blank
blank
blank
blank
Blank
blank
blank
blank
Blank
blank
blank
blank
Blank
blank
blank
blank
You use this character → |
Create a table on your Discourse forum With the new markdown engine (since the version 1.9.0 b4), creating a table is really easy. For this howto, we will use a table with three columns. You can create a table with as many columns as you want but...
Reading time: 3 mins 🕑
Likes: 164 ❤
Ok i started to make the table. Not fun to do on phone will try at computer tomorrow. If you guys can throw links and photos in the thread i’ll try put them into tables
jaykup
June 1, 2022, 1:53pm
#8
You can also make it in a spreadsheet like google sheets then copy/paste into the forum. It will format the table automatically.
Woah that sounds heaps easier
RDs
June 1, 2022, 1:59pm
#10
Can discontinued pulleys also be added? (Like 3DS ones)
Take what you need from my older guide Al, it’s dated by the humor is still
Push it in
I wanted to put together a quick guide for where to get some push fit pulleys that I have here and have used, mostly from our community vendors but it should be mentioned that many of the commercial brands have their own versions which may or may not be useful to us. Buy from our dudes though
[Pulleys]
This is going to be focused around the ones I have and my experiences with them, that way I’m not pulling info out of thin air and misrepresenting anyone. Vendors, I welcome …
Dinnye
June 1, 2022, 9:42pm
#12
The dickyho pulleys can be used both in a bolt-on and in a press fit configuration. I added this info to the OP.
I do have 42T, 44T Kegal, as well as 42T abec press fit.
(Also have a few 60T press fit Kegal and a few 60T bolt on for six shooters, but won’t be making any more of those)
