Do I need to be concerned about hooking up my ESC’s without anti-spark connectors? I’ve got some large resistors I could use to connect them but if it’s not necessary, than it’s not necessary. I’ve hooked them up before without a precharge circuit without issue but if there’s any chance whatsoever it could damage these ZESC Raiden 7’s then I’d rather err on the side of caution.
Hi,
Finland seems to be on of the countries where DHL is really expensive.
That said you could probably order loads more stuff and it would cost the same shipping cost.
We’ve deviated from our shipping supplier on a few occasions and hasn’t always worked out well and there is actually still a parcel lost in Germany.
Working up some CAD files for some bull bars and realized that it’d taken on the form of a white pointer maybe I should be adding teeth and airbrush it as a shark
Help I’m stuck between two decks and can’t decide.
Demonseed 39
-or-
Fixed Blade 40
Gonna slap on an eBoosted switchblade enclosure with a really forgiving gasket so I’m not to worried about compatibility, although planning on using 120mm wheels on BN 270mm RKP with rear mounted BNM1.
