Title maybe a bit overstepping, but dang you guys this thing is a machiiiiine! Like none I have ever ridden
Here is the parts list
Landyachtz evo 40
Eboosted Double stack 21700 enclosure
Some cheap Amazon carbon fiber vinyl
4wd TB Direct Drive (limited edition Extra Large)
Dual Stormcore 60D
Skyart 12s8p Molicel P42a
Giant 20amp charge port
TB AT and AT adapters for direct drives
MadFury Adjustable Base Plates
Here are some picture
Like most of my builds I started with seeing how much battery I could get into that enclosure…turns out it was quite a bit! 12s8p…and looked like just enough room for some Stormcores
So I built the pack, decided on 1 pieces or #10 for series connections…supposedly that’s good for 240amps…lol will be hard to pull that much even on 4wd.
Evo decks seem to be in high demand, couldn’t find one. Thanks to @Brently tho, sold me he used deck. Above is the pick of the cheap vinyl botch job i did on it. Came out okish
The rest is all assembly and programming, with these Torqueboards direct drives, assembley couldn’t be easier, litteraly took less then 5 minutes lol! Just slide motor onto hanger, add wheel, tighten wheel nut…done. so painless!!! Highly recomend.
Davega because I had one…and I love it! Deffienlty a must for anything that you plan on sinking money into.
Here is a few more pics and a bad video
Did 40 on its maiden voyage, since then I bumped the settings to
100/-60 motor
100/-40 battery
This is per stormcore.
The amount of torgue and how fast it gets to 40 is mind blowing i have never felt this kind of acceleration. Absolutely thrilled with its performance! Soooo insane!
Working through a few Stormcore 4wd issues. Had to reprogram a few times today, but the Lacroix individuals have been very helpful, hoping everything will be smooth sailing from now on. Will post more ride logs and hopefully better videos soon
Thanks yall! Stay safe out there.
