Plutonium Slayer - 4WD TBDDxL 60kv|18s5p P42a| Dual Stormcore 100D
Love it :exploding_head:
I don’t think your build is in any way related to this monster.
This is no tea cup party This is the real deal lol
What a monster :exploding_head:
I was going to go with Plutonum defenestrator…but slayer had a nicer ring to it.
I litteraly take only 1/4 of that blame…maybe 30% the rest is on you homie…or with you I guess
What’s the diameter of these wheels? Are they pneumatic?
160mm pneumatic wheels, they use 8" compatible hubs
What @ZachTetra said, they are closer to 165. But yeah, the hubs fit 8" roadies, which might be an experiment down the road
I thought AT wheels were incompatible with TB DD? Maximum 110 mm diameter?
Not incompatible, just low torque. On 4WD it’s okay though
I see - missed that. Thanks!
this is not the standard TB DD these are a limited edition Extra large ones about 30% bigger then the standard stuff. I think @torqueboards will sell you the AT adapters for Standard DD if you purchase 4wd worth of motors
Also 2x dual Stormcore ESC?
Correct, although there are several canbus issues I am having between my 2 stormcores. I would not recomend using these for a 4wd set up yet. Still some bugs lacroix needs to figure out
Looks awesome! I can imagine how nice it rides.
Not sure if 100D will have the same issue, and likely this will get figured out. Seems ibam the only one with this issue. From the looks of it bioboards is not having the same issue lol. Maybe user error? But I’ve tried sooooo many things lol
The only Plutonium slayer is this board:
JK, nice build! How are the DD working with AT wheels?
Try connect ground
