It wouldn’t be significant.
No they don’t
I’ve been waiting for a month for Zeus - it should come in mid-December. I have read and watched a lot of stuff and decided to order a 13T and 14T motor pulley for it right away and try them on test (I care more about acceleration and braking than maximum speed). Now the main question: can someone advise me where I can find it? I am looking for it and it still seems to me that what I find is not appropriate.
Any ideas aboud specyfic shop - Im from Poland, so enything from EU will be appreciated.
Sure go to:
dang, meepo has drop their AT-only option
I’ve got close to 500 miles on my Zeus now… switched to stock 97s about 100 miles back and likewise kept the 44T pulley on… bc 30 mph is usually fast enough for me.
Also coming from longboarding… I really like the feel of the PUs… but am craving some of the crack handling that the 120 clouds offered.
So… I’m prob going to get some 110 TB or 111 Abec 11 PU wheels soon.
Yes, but I still think ZEUS is much better for me because of the range. meepo, with its appetite for power and smaller battery for my tastes, is just balanced in the wrong direction. If the meepo had ZEUS-size batteries, I would probably choose differently.
please elaborate
12s4p p42a is one of, if not, the most common battery config starting from this year, which wrong direction did it take?
I dont care so much for max current, but for capasity → 725 Wh (Hurricane) vs 898 Wh (ZEUS), and because meepo has so much power, the gap between bords is like almost 30%. I am living in cold area, and my weight is over 100 kg, so range estimation (from dkwan page and films on yt) is like 30 km on ZEUS and 22km on meepo (if i would like to totally drain the battery - what is not so helthy for it). So for me this is easy choice.
That range calculator is not considering factors like sag. If you’re pushing the boards hard with the same setup they will get the same range. In the cold the meepo should actually do better as it’ll sag less.
guys. I just need an advise where can I find proper motor pulley, not the discussion witch board is better. I already decided. So pls. help and focus on subject.
Consider the Eovan Carbon Super. Seems like a good balance of both (plus VESC).
13t will give you slippage issues. We don’t recommend going below 14t. If you need more torque after that look for higher tooth count wheel pullies.
Yep this ^^
I don’t think anyone makes a 14t 10mm D shaft pulley
" Shaft size : 8mm (Stepped from 10mm)" - from manufacturer side
Yeah I’m really looking at the abec 111s but don’t know if the difference from clouds or 97s would be worth the steep price. Let me know if you go for it!
did you end up buying both?
This is the best solution if you have the cash to pay upfront. You can literally sell it to a local rider for the black friday price after a month of having fun and riding it. (Assuming you take good care of it and dont totally trash it)
they are giving 5A charger now ? since when ? before it was 3A or I mist something ?
Yeah they switched to 5a
