"Nothing Fancy", A Tito Duality truck build
If you incorporate titanium, flint, zirconium or magnesium in the skid plate it would drop a shower of sparks every time it contacts the concrete, just like an Formula One car.
Corded my set of CSTs, put on a new set of Kendas I was gifted.
(Keeping my set of NOVAs fresh for EE SanFran)
Had an absolute blast at electrify expo this weekend!
Went on a ride through downtown San Francisco Friday night with the floatpack
I got a nail through my tire early in the ride but I didn’t have a spare tube… so I just ran my nova’s flat for 15 miles. Unsurprisingly, the tube was not happy about this.
Changing out the tube when I got home, the Tire wasn’t happy about that decision either.
I pulled out the several feet of steel cord that was loose on the inside. (all of this came out of my tire)
Turns out I somehow extracted the steel cord out of the bead of tire by riding :upside_down_face:
Now a tire short, I bought a set of Linnpower NEXT slicks from Poast. I should’ve done this a long time ago, these tires are awesome!
Thanks to the Lins, I qualified 5th on Saturday, finished 3rd in the final. I qualified 4th on Saturday, finished 4th in the final, giving me 4th overall for the weekend.
Sunday’s Mod Final:
Not Nothing Fancy, but I really want to share these awesome photos of me on Ankle Wreacher, taken by 15 year old Mia Loblu, who raced in stock class. Keep an eye out for her, she’s some real up and coming talent.
I did a writeup thing in another thread, it’s relevant here
Oh good, i was just thinking that I wish I could like your post a second time :smiling_face_with_three_hearts:
Jimmy caught some sick footage of me sliding through the corners at SD i2s a few months ago, wanted to share here. Kenda tires are so much fun to ride.
Thought that this had been posted here already!
Getting back into the swing of things, first day in a few months time really pushing on track.
So much fun sliding on Kenda tires
Feels good😎
thanks @TheSharpergardner for the vid!
Decided to change stuff up and threw a set of Linpower slicks on the board a few weeks ago.
Thanks @HAIRYMANJACK for this candid from i2s garage night Wednesday
Was gifted a new set of tires at track on Saturday, and put them on the board.
At track tonight, one blew up and caused a crash. I’ve never gone through a tire so fast, so I wasn’t even checking to see if it was close to cording😅
Had lots of fun drifting them though!
(Thanks @MarioChacon for the candid!)
Fresh CSTs. Thanks Ralph!
TUCKER WHAT DID I TELL YOU??!?
THIS ISNT TOKYO DRIFT!
Lol.
But seriously sweet drifts!
Mt. Baldy with my dad.
He loves this board, and is going to be racing it in Master’s class at esk8con
I wasn’t sure where to put this, is axle space still an issue?
I turned down some nuts on a lathe and could do 7/16 x 20 threaded nuts too if it helps.
if you look up (size) nylock jam nuts, you should be able to find some thin nuts around the same size you ended up with
These are a good bit thinner than that. There’s about 2 threads left in the nut and the ones behind it are only slightly taller than thin M12 nuts.
I mean I could make longer axles but I’ve aready promised someone else a set and the only chance I get on a lathe atm is unofficially joining 5th year metalwork classes on days I wasn’t supposed to be in.
I’m the only one to have skipped negative three classes :rofl:
That much thread engagement seems good, another way people do it is to screw the nut on backward. Or else, but some blue loctite on the nut, seems to work just fine.
Nothing Fancy’s been doing great lately.
With my dad racing on it in a few weeks, It’s a good time to give the board a once-over and tune-up.
Tires
Selecting a tire
On my shelf, I had a bunch of decent options for different tires
  • 200mm CSTs
  • 6" NOVAs (Thanks James)
  • 7" NOVAs
  • 8" NOVAs (Thanks Allen)
  • Linpower Slicks
My dad’s a decent rider, but he’s not a “”““racer””“”, so I wanted the priority to be on comfort(So no small tires) and stability. On the off chance he does start sliding, I want a forgiving slide profile to help him recover from it (so no linslicks, I’ve found their sliding to be rather abrupt)
That leaves the CSTs and 8" NOVAs. He’s going to be racing, so traction is the deciding factor. NOVAs > CSTs
Allen Powell very kindly gave me with a set of 8" NOVAs. You’re awesome dude!
I’ve been running 200mm CST tires for ~the past month on MBS Rockstar II hubs, my Linpower Slicks have been sitting on a shelf. However, I need to steal the hubba hubs back from them. Some light prying later,
And on go 8" NOVAs, stretched onto the wide hubba hubs.
The new stance is growing on me.
Megan Install
For how amazing she is, Nothing Fancy totally deserves to have a Megan.
I bought a broken Megan from @Ash and repaired it (check out this thread for details)
Made a custom terminated CAN cable
Drilled a hole in the deck for the power switch and the new CAN cable
Threw the Megan baseplate on top of the handle mount
I started designing a whole custom box for the front to neatly integrate the power switch with the handle and Megan, but then I realized that it doesn’t matter and I don’t care, so I just hot glued the button
Mint.
Already feels like it’s always been there :checkered_flag:
Opening her up to connect the cables and do an inspection, everything looks in shockingly good condition for how many miles she has.
re-routing the switch through the new hole also meant that it’s long enough to not need to unplug it anymore when going inside the enclosure, which is nice.
Charge Port
While I was inside, I opted to change out the charge port. It used to be a Male XT60 hot glued to a 3D printed adaptor thing. what in the world was I thinking when I decided to use male XT60…
Had to do some minor enclosure modification,
But now it’s a proper panel mount XT60 Female. Should be a lot safer and durable then the Male XT60.
There’s something profoundly special of the state of a messy workbench at the end of a task
Approval from the on-duty inspecator
Caution
While reassembling the board, I noticed that the right side had a subtle rattle that the other side didn’t.
Now, I would normally write something so subtle off and not bother fixing it. However, I’m lending it to my dad for the weekend. Safety standards are higher then normal.
Opening up the drives for the first time in forever
Oh… Oh no.
AHHH
W. T. F.
I took apart the other side, to see if it has the same issue.
Nope.
So, the bearing went bad and started rubbing against the axle?
That’s the wild part- the bearing is totally fine
Me noticing this a tiny rattle turned into a complete drivetrain disassembly, and deeming the board inoperable a few hours later.
sigh
Louie captured my mood pretty well
Wild speculation about the failure mode
I have a couple theories;
  1. They’re 12s motors that I’m running at 20s, so can’t fault the motors.
    and tbf, Apex did mention this when I asked about running them at 20s when I purchased em. So maybe the motors were just WAY out of spec and there was nothing I could do.
  1. It happed only on the right side. I’m regular, putting it on the outside for heelside turns. I frequently ride on track, frequently pushing harder on heelside turns then toeside turns (skill issue).
    Doing heelside turns, it wasn’t uncommon for me to unweight and spin up the outside tire. Mario actually captured a video of this happening (last video in post 212)
    Perhaps the fact that it spun up to such a high speed and/or snapped back to a normal speed caused the damage over time?
  2. Perhaps just enough gearbox juice leaked out of the drive, and down the shaft of the motor. A little bit got under the bearing, which allowed it to start sliding on top of the shaft. Once it started sliding a little bit, progressive damage to the shaft allowed it to happen increasingly frequently and causing increasing amounts of damage
Perhaps all three are wrong, perhaps they all had a part to play.
YARN | I guess we'll never know. | Futurama (1999) - S06E15 Comedy | Video clips by quotes ...
[/quote]
So, now what?
I can’t keep using these motors (safely, at least).
So I’ve got to replace the motors.
Kinda okay with this tbh, I wasn’t a huge fan of the Apex motors anyway. (relatively) inefficient and very, very loud. They were the weakest part of the build, so of all the parts the could’ve needed replacing, I’m glad it’s these.
Exact route TBD, but I’ve got to solve it in the next two weeks for my dad to race with. Should be possible to do.
For now, I’ve cat-safed the workbench and set it aside as a problem to solve later this weekend. Being busy and having way too much to do is better then the alternative, I suppose :slightly_smiling_face:
Wanna borrow my Reachers?
173kv
Yo I got a spare working flipsky zoobomb can if you want it has a bit of the same wear but not as much let me know :call_me_hand:
Thanks for the offer! But those are for your raceboard, not mine😋
It’s compatible with these apex motors, at least the shaft is? That’d be sick! How fast can you get it to me haha, I need this board in time for esk8con.
Alternatively, are you getting to Vegas on Thursday?
