When you were at carve did you see what @jack.luis did with Rocinante?
I can’t seem to find a picture at the moment but he’s got full coverage with skid plates stuck on there with 3m tape. Seems relatively cheap and easy, plus you could still do something like tap threads in the metal for mounting the spark rods.
Slightly different use case though- my scraping is localized more on the edges of the enclosure, so I’d wear through the edges of a plate pretty quickly.
I’m was shooting for a something that’s more easily replaceable. Not sure there’d be enough depth for threads, but might be worth a shot. TBD, thanks.
@Titoxd1000 graciously made me a hanger with longer axles so I could run Hubba hubs with the Apex Drives
He’s considering 10mm customs too, you know who you are
The CSTs seem to want to scream even louder then my Kendas did
Super excited to push them on track Tuesday- The SD Zoo lot has the screachiest possible asphalt.
I’ll be running CSTs for the next couple weeks, but I’ve got a fresh set of NOVAs that I plan to race with for EE San Fran next month.
Interesting, when disassembling my corded tires, I noticed that one of the hubs had adopted the serrations of the Kenda’s bead.
Looking closer, I noticed there was a whole thin layer of rubber deposited, seems to be bonded to the plastic. Perhaps I overheated a tire… but still Weeeeird. Anyone ever see something like this? @MBS ?
(mostly unaffected hub on the left)
It’s tough to tell from a picture, but my first impression is that the “deposited material” looks more like melted hub material than melted rubber material (the tire doesn’t look damaged at all). In theory the melting points should be similar… but that depends on the exact formula Kenda uses for their tires.
The RSII hubs would have to get VERY hot to melt (>220-250C), so it’d be surprising, but definitely not impossible. My hypothesis could be wrong of course. I’m just going off of what I see in the photo.
Has anyone else ever seen or heard of MBS RSII nylon hubs melting like that?
Ah darn, you’re totally right. I should’ve noticed before posting it😂
Those hyper trucks felt like there was a cat inside the enclosure bouncing off the walls trying to get out. Shocked I was able to get that much lean angle😂
