Took the board apart today to install a puck remote. I’ve given up on OSRR availability, and I don’t really need a remote with telemetry if I have Davega.
First things first, I wanted to check if I had a loose wire or something that would explain my VX1 FULL disconnecting. Well, it seems like I did an overkill job securing and insulating the receiver wires, so conclusion: not user error, VX1 is just crap. I also had the VX1 in my small board disconnect fully once, so I will be swapping that one out too.
I also wanted to make some space for the 12V buck converter, so I made an extender cable for the battery’s XT-90, that also splits off into a switch → fuse → buck → fuse → external accessory port.
Battery is secured with double sided tape and foam on the sides (it’s not closed cell, but it’s all I had), and then I hot-glued things like the flexibms and buck in place. This is the final enclosure layout: (it’s tight!)
I put some neopreme foam sheets on top, and bolted her up for good (fingers crossed).
Then I cut up a 12V side-emitting LED strip, and hot-glued it around the enclosure. It doesn’t seem to hold well, so there’s a big chance it’ll fall off. Will have to check up on it while riding. Worst case I’ll use epoxy, but that means it’ll be permanent ![]()
Once the threadlocker cures I’ll ride to a more scenic place for final pictures (still have to powder-coat the duck handle too!), but here’s a few pics in the meantime.
The puck color doesn’t quite match, but I might swap it out for a different shell anyway. I also bought the glow-in-the-dark shell, but it’s very underwhelming, like most glow-in-the-dark things are. Thanks for reading!
