simply bind 2 receivers to the same remote
Is at actually possible
Never seen that do you have to bind both at once or one after the other
how long should a battery sit and can i discharge with out hooking the balance plug into the balance charger/dis-charge?.
Not sure if this is a ātrueā noob question but -
Whatās the general opinion on the Flipsky dual 6.6 plus?
Itās in the thread
Gotcha thanks for the help
What do you think is better multiple receivers or split ppm
Youāve been around too long to ask Brian this question. Come on, man!
Iām not allowed to answer that question.
However, indisputable facts are that my last dual build had 2 receivers in it.
I canāt discuss why, or which I think is better.
I will take your word for it
I am waiting to receive some connectors for split ppm and for single
Once I receive I will see which works better and base it all on that
I already have two receivers and bind plugs so good there
Wow so well behaved brian
On the contrary of some sparkly princesses
Iām a sassy bitch
So am I but Iām a bitch with a chargerā¦
Bastardā¦
Whatās wrong?
Can an xt60 realistically handle charging at 15 amps for 1-2 hours?
Ok thanks!
Yes @anon54720240 is correct; the XT60 is rated 60A continuous which roughly translates to 120A peak for a few seconds. 15A continuous charging is no problem at all. You should fuse the charge circuit though. Just not the discharge circuit.
dont buy it
