How to use a loop key ?
Thanks
Also, these right cheer:
Speed modes are for UART mode, and only changes the acceleration curve not top speed. Stupid I know.
What a braindead functionality choice. Defeats the purpose completely
I found this out after letting my 6 year old try my new board. I thought having it on one led would speed limit. It didn’t.
But metr pro came to the rescue.
Ouch, hope the young bloke was all good
ALL HAIL METR
Is there any thing do, all hail metr.
I can’t tell what’s going on here. The left belt keeps loosening up. I am 99% sure that it’s not the motors coming loose because it’s not moving at all. The right one has been solid. Could have putting them on too tight originally caused the left one to stretch? I think I also had put the right one on tight as well but it has been solid.
Are they different makes one has blue writing one doesn’t.
what material would people suggest i use for a thick gasket (12-15mm):
or
2. Neoprene Rubber Black Self-Adhesive Sponge
thanks
No I took them off and checked. They actually seemed the same size (belts not the cause) but motor pulley was loose. I think the first time the motor was loose. Then the pulley got loose.
but the thing is, i don’t see any acceleration differences either
You are not using UART you’re using ppm…
The acceleration modes work in PPM and UART.
Only uart provides the reverse mode.
Wait until you hear what cruise control does on the vx1
it has cruise control?
Yea. It locks the acceleration amps
Assuming you reached a balance point on straights, the first downhill street would see you flying at 50 an hour. Useless.
