@zZoKo swap 2 phasewires on your motor
i tried but it makes a screaming sound with no moving
then just reprogram ^^ It should fix it
damn i just taped it all up and everything
Hey guys
Anyone knows something about this deck:
I can’t seem to find anything online other than this link
Opinions?
Thanks,
Dani
You got 2 options
Change 2 phase wires as already mentionend and do the detection again.
Or
Rely on software. Connect the board to your pc or phone and change the direction via software, no detection required.
btw with big pneumatics anyone has the problem of being thrown forward when letting off the gas? i almost fell
Could be the drag of your pneumatics or your belts are too tight.
You do feel something but ut shouldn’t throw you off.
idk but i think im choking that poor single vesc to death with only one motor on 8" wheels maybe i should convert it to a street board…
Or make it a double.
nah thats double the trouble
This is true, and it also stops when then cells are within a certain voltage difference. Check your “Parameters setting” menu for these values, and adjust them if you like.
what are those threaded inserts that go all the way through the deck called?
thanks
Do they have a special name? I thought they where just long threaded inserts lol
nah they are different ones
rivet nuts i think
they arent installed like inserts rather clamped into place
sex bolt
yep thats the one
thanks
anytime
