So I took the knockoff trampa apart how can I switch these 8mm bearings to 10mm that Shizz ain’t coming out is there a tool or am I just a Puunani
sorry I dont understand
Can you try using the original switch as a test?
@Accrobrandon I watched your video thanks it help me with these ch clones https://electric-skateboard.builders/t/chinese-superstars/73166/218🤙
@kook I got it …For science
anyof u guys know what colur the temp sesore wieres on the raptor 2 are ?
They already told you bro. Pretty sure they said white but go back and read what’s been posted.
thiers no white ill drop a pic
Who are you and what have you done with Kook?
Im in san jose. Depending on the issue, I might be able to fix it for you, I sent you a pm
If I had to guess, I’d guess
black / gnd
red / +5V
purple / temp
blue / hall
green / hall
yellow / hall
but that’s a guess based on my experience. You can connect +5V and Gnd and then turn the motor slowly and the three wires that go on/off/on/off as you turn, those are the hall sensors. The last wire will be the temp sensor. It won’t change voltage as you turn the rotor.
The hall sensors can be connected in any order, the software will autodetect the order when you do a motor detection.
Cheers
What issues?! Leaks or the rims ?!
oh shit a another guy sia it was the yellow one, im assuming u mean the purple wire
it’ll be a 10K thermistor inside the motor connected to ground
on NORMAL escs it’s the pin adjacent to 5v pin…
on your piece of crap I have NO idea
cut the temp wire no my my motore just wiggle
this makes me smile
ur a savg
and yet I skate…
n U hve no werkIng broke-Dick motre
how much money u got bitch
if literacy and comprehension were a prerequisite to breathe… you’d have been still-born…
