Vesc tool app. took if for a spin happy
Hello! What motor pulleys would you recommend for 12" (308mm) Flipsky double king pin trucks? From what I’ve gathered the press fit pulley’s need at least 40mm+ axle to work. I believe these trucks only have 34mm of 8mm diameter axle on either side. I originally bought the trucks from banggood, but they haven’t arrived yet. If press fit pulley’s aren’t compatible, could I use the bolt on style pulley?
Interesting information actually. It seems a lot of manufacturers got this wrong entirely.
Even saying “VESC Tool app” is ambiguous because there are multiple versions and Linux / Windows / Android / other versions
Those could also be designed for maximum liability avoidance. Not saying they are, saying they can be.
I always use the XT60 as a 60A continuous device.
Hey. To the guys who use the riptide tunnel riser. What riser you use to match in the front?
Can someone direct me to a thread or info on logging in VESC Tool android app, or a comparison of different logging options? I’m not against buying extra hardware like a Metr Pro but if there’s a sensible way to use the unity’s NRF module that’d be great
Same here.
If anyone ever needs an esk8 remote, I’m definitely recommending hoyt just for this. A whole new pcb unit with all the necessary parts and battery, is something I love to see.
Another Riptide Tunnel Riser.
how would i go about extending motor cables?
Extend your esc wires or make an extension
cant really move esc so i would need to cut the cables and saw a new piece inbetween i think
Then an extension adapter would be your best bet.
got a link to one
Sir this is a DIY forum.
( i don’t know what connectors and or wire thickness you have)
i think i got the medium standard one
medium standard what?
girth
…of cable
